Swapped my ma785r board to a new case and need the pin layout for power switch and reset switch
    Guru:
  • 551 Answers
Please search on the web on the model of your new board.
Posted on May 13, 2010
2 Suggested Answers
grantg1983
  • 218 Answers
SOURCE: swapped my ma785r board to a new case and need the
ok i dont hqave it but as i buld a lot of used pcs and new ones its usaly goes like this there is a 9th pin and a tenth one missing next to and in a straght line down the way nest to where the missing pin is is the on of under it is the reset pins next to the reset one is the hdd led and that leaves 1 set of 2 pins left if you want e mail me and ill draw a diagram for you hope this helps
Posted on Mar 17, 2010
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Mar 17, 2010 | Computers & Internet
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
Jul 27, 2009 | Dell (E210882) Motherboard
Dell GX270 SATA front panel 34 pin layout
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
the link below should get you started
http://www.intel.com/support/product.htm
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
Will not turn on.
Did you try bypassing the switch?
To do so:
  1. Remove the case
  2. Follow the wire from the power switch to the motherboard
  3. Remove the wire from the 2 pins
  4. Use a screw driver and touch both pins at the same time, creating a connection
That would be the equivalent of switching the computer on, if it powers on then you know the switch is bad and just need to replace it. If it does not turn on I would be 99% sure it is the motherboard as you already swapped the power supply.
Feb 24, 2009 | E-Machines T2984 PC Desktop
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Nov 02, 2008 | Asrock 775VM800 Motherboard
Where are the EliteGroup nForce3-A power & reset plug-ins located at?
Goto page 10 in your user manual. There look for. Connect the case switches and indicator LEDs to the SW1. (Location).
There is mother board layout decription for how to connect the case, 2-pin wires case connectors ( Page 12 shows pin numbers & which is plus + & negative - pins.). You'll nee the manual to help you. Download it from ECS at: http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=579&DetailName=Manual&MenuID=48&LanID=0
Mike
Aug 12, 2008 | EliteGroup nForce3-A Motherboard
I just bought a new motherboard and managed to swap everything....except the power switch cable
whew..that's not as simple as it looks. You'll need a pin out configuration guide, if one exists, or you'll need to make one. The power interface from front panel, is usually unique to each Dell, so its' not likely to swap over.
got backup for that Dell?
Feb 17, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
518 people viewed this question
David Payne
David Payne
