Question about Cycling
The chain is too lose how do i tighten it. - Cycling
    Habit-Forming:
  • 25 Answers
You need to cut off one or more links, normally if your bicycle has gears, you should put in your biggest cog and chainring and add 2 links. To do this will need a chainbreaker or get it to the bicycle shop.
Chainbreaker cost around 5 dollar but sometimes is a little tricky to do.
Posted on May 18, 2010
The chain keeps slipping off my craftman gas chainsaw
You need to tighten the chain. Loosen the nuts that hold the blade on just a little, then look on the inside of the blade. You will see a screw to tighten the blade. The chain should not be tight. There should be a little space between the chain and the bar. You should not be able to see the guide teeth of the chain. Just about 1/32 of an inch. When you tighten the blade back up, if you had it too lose, it will tighten the chain back to, too tight.
Jun 09, 2014 | Craftsman Garden
Tighten chain on WEN 5041 electric chain shaw?
First loosten that 1/2 bolt on the bar--the lookat the bar when it goes into the housing you will see the adjustment screw.Tighten the chain by turning the screw when you get it to where you want it then tighten the 1/2 inch bolt
Nov 05, 2011 | Electric Chainsaw Sharpener
Primary drive chain seems lose
Your Big Twin primary chain should have 3/4" to 7/8" up and down travel when the engine is cold. As the engine heats up, the aluminum expands and the chain should have 5/8" to 3/4" when hot. Take the inspection cover off to check the tension. If you have an adjustable primary chain tensioner, loosen the nut and lift the adjuster to tighten the chain.
Steve
Jul 25, 2011 | 2004 Harley Davidson FLHTCUI Electra Glide...
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in bar....pin sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Hi i have a husqvarna 450,any time i cut the chain seems to expand and gets too lose on the bar, i had the tension tightened to the last and the chain was still to lose, o and the chain is the right size...
Can be the chain tensor or the chain itself that is streched.Also make sure the bolt and groove are ok.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 12, 2011 | Husqvarna 450 e-series 18" Chain Saw
I have a 500 ex and the timing chain is a little lose i have tightened it befor and it came lose again is there some thing im not doing right?
You have to have the slack of the chain at the adjustment side. or the loosness can be on at another portion of the chain, preventing proper adjustment.
Sep 27, 2010 | kawasaki ER-5 Motorcycles
Chain keeps getting lose so i tighten it it get lose now it make a noise what is the problem
Get your rear wheel off the ground. Spin the wheel observing if the chain rides up and down the teeth of the sprocket. When this is happening notice if the chain is getting tight than slack, then you know you have a stretched chain (maybe only a 1 foot section). Replace the chain. If the sprockets are worn you may be able to save money by purchasing a chain and sprocket kit. If it is a seventies vintage Honda, they had a fiber bushing for a swing arm bearing. They were noted for failure causing the chain to bounce off he frame and swing arm . A loud banging sound while you ride.
Sep 25, 2010 | Honda VF 750 S Motorcycles
Chain wont tighten up for Poulan 295 Pro chain saw
hi after awhile chains stretch, make sure they get oiled good. nut that holds bar must be lose, like a 1/2 turn then you can tighten screw . don't over tighten ether of these. it takes time to find your saws happy spot , so be patient and keep trying to tweak it tell ya find it..vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Jul 18, 2010 | Poulan Pro Chain Saw 46cc 20"
I need to change the Oil pump chain, it's lose
There is an adjustment so that the chain can be tightened
Oct 26, 2009 | 1995 BMW 5 Series
Need parts for WEN model 6014 chain saw
there are none realy take the two nuts lose take a flate head tighten the chain now if you can pull the chain easy around the bar you good this will give you about a 1/8 in sage on the chain...Good luck
Aug 16, 2009 | Electric Chainsaw Sharpener
Cycling Logo
35 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
