Question about Akai LCT2662 Television
No Power to AKAI
I saw your solution about changing the caps. Since I have no clue what that means and my husband doesn't either. How would you go about telling a repair man what to do.
please advise.
  • 934 Answers
I persoanlly would tell him to remove the power supply and replace the capacitors as needed, the common failure of this module in this chassis TV. Or you could have your husband take the unit off the wall, remove the back panel to access the boards and unplug the power supply himself and send just that in for repair. He would be VERY surprised how simply that is...
The power supply in this unit is clearly accessible. A few well marked connectors to unplug and some screws that hold the SMPS to the board. Then simply send it to PTS or any shop of your choosing and get it repaired. Then simply re-install it..
Last one we repaired here in the shop was $234.50 including tax.
Bill
Posted on Mar 31, 2008
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
LCT2701ad switch on display logo ten off
Change input device to some other like a DVD player and see. Look for any loose contacts in power outlet, RC jack, cable or socket. Look for any jammed buttons on remote or on control panel.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT2715 27 in. LCD Television
Ive got a akai lm-h30 cjsa lcd tv that gos on one day, and not the next, green light flashing and clicking please give me a clue
The first place to look will be the power supply, inspect it for bad caps with leaking/bulging top.
You can learn more here before DIY. If you really need to get down deep to component level, you will need the service manual.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Please post back what you find.
Jan 05, 2011 | Akai LCT2715 27 in. LCD Television
No 12volts and 5 =volts in secondary transformer
change all 470mf & 1000mf caps fix problem
Mar 18, 2009 | Akai LCT2662 Television
LCT3701ad AKAI tv
hello can you see a back light on the tv if no it could be inverter board it self if yes the may be dry joints on the transformer on the inverterboard also check all the cable connections on the main board make sure the contacts are clean and fitted tightly good luck
shaun
Feb 22, 2009 | Akai LCT3701AD 37 in. LCD Television
LCT2662 turns on, no picture
Mine is the 5volt regutator. It works fine untill I put a load on it then it craps out. Need to know what the 5v regulator part # is.
Dec 22, 2008 | Akai LCT2662 Television
Akai LCT2715 No Power
I have a different thread going, but saw yours and had a question. Is your light blinking steady and then off? or is it a blinking erraticly or even flickering? My bad caps (15 of them) were all on the secondary side of the PSU. I have been told (thanks to Jaimie Hernandez) if you have a steady blinking, then it is very likely that you have a bad zener diode Z3(27v/1Watt) shorted in the primary side of the power board. If that diode is shorted, it's very likely that 2 10 ohms resistors might be open, these resistors are connected to the cathode of Z3. Also check for bad caps on the Primary side.
I had a huge incentive to fix the TV, it is my wife's TV and she has been in my Man Cave since it died. How about that incentive.
Good luck
Gallagher68
Oct 19, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT 2662 power supply
Call 800-726-4405 - if the television cannot be fixed because the parts are not available the television must be exchange - by law
Nov 26, 2007 | Akai LCT2662 Television
Akai LCT2662 Television Logo
42 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
