Question about Mitsubishi CS-35405 TV
Ant A and ant B
How to swtich from ant A to and B using remote?
There should be 2 buttons labeled Input, in between Volume and Channel. Press up on Input. If you are using a remote different from the one that came with the TV, then look for a button labeled 'Input' 'Int' or 'Mode' somewhere along the top.
Posted on Jun 17, 2008
We have a Model # 50GX49B 50" inch TV, That our
You need to set the antenna input back to ANT A (1), you are ANT B (2) right now that why you are not seeing any signals.
Use the INPUT button on the remote to scroll through until you see ANT A which is the one your kid use for the cable connection,
You should download this user manual:
http://www.retrevo.com/support/Hitachi-50GX49B-TVs-manual/id/371bh845/t/2/
Let me know if it works.
Dec 31, 2010 | Hitachi 50GX49B 50" Rear Projection...
Dish hd dvr remote won't work. brand new. it
It sounds like you have interference, try removing the uhf ant from the back of rec and promgram it straight from there. you can also hookup "bunny ears or a pigtail coax to the uhf ant port to increse uhf signal. also make sure the uhf ant is standing straight up.
Nov 13, 2009 | DISH Network 721 DVR Remote Control
My tv just started to look like if I didn't have cable it has a breeze
must be off channel, if using cable box make sure its on ch 3, also check Ant switch on remote if two ant inputs
Aug 28, 2009 | Maxent MX-42XM11 Television
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
Aftermarket amp installed on 2006 silverado
connect the remote turn on any wire that goes hot when the ignition is tured on
Jun 01, 2008 | Car Audio & Video
Eas tv model et427e
Using your TV remote (not the cable remote) use the input/select button to swtich to videe 2 or ? ; this should allow DVD to work/ when done use remote input/select button and switch back to video
Dec 23, 2007 | Televison & Video
Input problem
your tv is set to "Home Theater mode" . Use "menu" key on your remote, go to "advanced feature", then go to "use home theater" then hit "cancel" to return to standard mode. If this does not work try unplugging the tv for 4 hours to return to factory default settings
Nov 07, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
