Craftsman model 358.791042, gasoline weedwacker wont stay running
Craftsman model 358.791042 gasoline weedwacker will idol but when I squeeze the trigger full throttle it dies. What should I try. Already installed new plug and air filter
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ...
Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Don't fret for now. Did you run the machine after? If so, there probably was enough residual oil mix still in the the tank/system to cover you.
If you did not run it, simply dump the gas in it and add the proper mix.
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH Lou
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
