I have a behringer modle GMX112 amplifier. When I
I have a behringer modle GMX112 amplifier. When I plugged it in smoke came out the back. Now I can get no sound when I plug in the chord. I can hear some static when I adjust the volumn. Is this an expensive repair? Can I do it myself?
  • Audio Player... Master
  • 5,487 Answers
Well the easy thing is that whatever is burnt up will be easy to spot and of course need replacing. So take the top off and see what you can see of it. That won't cost you anything. The problem is if the thing that has burnt up did so in a way you can't tell what it is! You will have a hell of a job finding out what it is. In which case you might as well let a repair shop do all the hard work! However if you can read the numbers of any damaged part(s). You can put them into google and find out what they cost etc. At least then you have the options of buying them yourself or working out what it might cost for fixing it assuming nothing else went!
Posted on May 14, 2010
I have a behringer pmp5000. At Practice one of the cables was stepped on and came out of a speaker.then, plugged back in immediately. There was some smoke and now the unit wont even turn on. Can this be...
Yes, it can be repaired. Likely at least the output transistors are fried, possibly the drivers are too. Possible other components like resistors gone, too. Needs somebody that knows amps.
Jan 20, 2015 | Behringer Europower Pmp5000 Powered Mixer...
No sound coming out on both r and l channel
Oops! Smoke from on of those is not unusual, as behringer is notorious for bad solder joints and BAD Power supplies. Anyhow the amplifiers are "most likely" OK. but your powersupply is shot. My PMH 3000 did the exact same thing. And here is the bad news. Behringer is also notorious for the lack of assistance in case of problems and will advice you to have the unit repaired at an approved service point. If however you are ok with electronics you can have a go yourself, manuals are few and (very) far between. I have some diagrams and stuff, so if you need some sing out. I have 2, MX 3282A mixers, nothing but trouble! Sorry I can't help you any further, Good luck.
Aug 13, 2014 | Behringer Europower Pmp5000 Powered Mixer...
Audio input line
Behringer Power Amps has the input lines on the back, it has either XLR balanced and 1/4 unbalanced inputs, now what are you trying to ask?
Oct 11, 2013 | Behringer EUROPOWER EP2500 Amplifier
I plug in the power lead and it makes a blowing noise the a spark comes out the back
The power amp blew... There is a marginal insulation in a circuit board that wipes out the rear-most power amplifier. Usually accompanied by sparks and smoke.
If the lights still come on for the effects window, then the power supply is OK and you are VERY lucky... have the unit serviced immediately.
If no lights come on now, the the power supply is toast as well. There will be about 20 components fried.
I know as I have repaired 4 of these... no fun, believe me!
Jul 16, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Expensive? Depends if the house burns down with it. Call the Fire Dept before the next time you turn it on. Kidding.
Only a qualified tech with an eyeball on the unit could answer the cost question. It sounds bad. Not only does the smoking component need to be identified but the cause of its demise might still exist.
Mar 17, 2010 | Audio Players & Recorders
EP1500 will not power up
check at the back for the small round fuse cartridge unscrew and chek the fuse is ok adn check the fuse in your plug
Jul 31, 2009 | Behringer EUROPOWER EP2500 Amplifier
A US 110v XENYX 802 plugged in a 220v power
please check the glass fuse sir. for sure it was blown out. if it is japan made and not been replaced since the 1st use im sure that only fuse has the weakest point so this will break out
Dec 05, 2008 | Audio Players & Recorders
Behringer ep1500 versus behringer eurolive b215 X 2- pa speakers.
The Amplifier will have wierd, notched, circular speakon cable connectors on the back, two, one for main left and one for main right. Press the button in on your speakon cable connector and twist it and lock it into place on the amplifer for right and left attachments, then do the same to your speakers.
Hopefully this helps.
Michael Lazar
http://www.AudioholicBlog.com/
Aug 27, 2008 | Behringer EUROPOWER EP1500 Car Audio...
Behringer PMX 2000 Amplifier
Hi aliciacarol,
The best place to go to get parts for Behringer parts I have found is straight to Behringer themselves, or an agent nearest to you. They are generally inexpensive to buy, and delivery are better than most. Steer your way to your nearest agent to you from the map . If you have any troubles, feel free to get back to me here. Good luck, thanks for using FixYa
regards
Graeme
Feb 23, 2008 | Behringer EUROPOWER EP2500 Amplifier
88 people viewed this question
 Grubhead
Grubhead
