Left earphone works, right one doesn't
Left earphone works right one doesn't
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 17 Answers
Wiring problem. you have to remove wire casing and re sauder
Posted on May 13, 2010
  • ronmeo Apr 16, 2011
    where would i need to go to do that?
Hp compaq cq43 not charging How to solve this problem
Posted on Feb 28, 2013
4 Suggested Answers
SOURCE: My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Posted on Mar 29, 2009
Grubhead
  • 5056 Answers
SOURCE: Right Earphone has stopped working.. left one
Sometimes the lead can break clean, internally, but most often it's inside the plug. If you are good with a soldering iron cut the plug off and fit a new one. But I would open the Right headphone first and see if you can see if the speaker works. They look like you will have to take off the pad first, remove any foam from the front, you should see screws to open it up.
Test the speaker with a low voltage battery, it will pop if connected to the terminals.
Posted on Nov 30, 2009
  • 174 Answers
SOURCE: left earphone works, right one doesn't
Probably a shorted wire and will need replaced. Some times bending the wire between your fingers will make it work again for a time.
Posted on Mar 17, 2010
How can I fix my phone cause now it let me listen through my left earphone only.
that should indicate to you that it needs to be properly diagnosed and/or repaired by a technician in a phone repair shop
Oct 04, 2016 | Cell Phones
Microphone doesn`t work
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Jan 05, 2013 | Dell Inspiron 15 1545 Notebook
Earphone-only left earphone works... how can u repair right earphone
Rotating the jack or twisting the wire joint on the headset might work.
Nov 09, 2012 | Bose Around Ear Headphones Earphones
Left earphone has lower volume than right
Maybe you can try adjusting the plug, or the wire within the left earphone is rusted, or change the sound effects on a computer.
May 03, 2010 | Philips Audio Players & Recorders
Shure earphone problem
There is no fix for that. They will need to be sent to Shure for repairs. Contact Shure Service.
May 01, 2010 | Shure E3C Consumer Headphones
Headphone problem
Hi there and welcome at Fixya, the support team (lfete)
Please try with another pair of earphones and see if it works :O)
If it works with the another earphones, then you have to check yours :
1.See if the cable and connectors are ok
2.Try to move the cable a little bit all the way (you can move it up and down)
3.Then be sure that it is inserted the whole way in, some times you can connect the earphone nearly in to the product, that means one of the right/left side will not play.
If is still not working please return here again
Hope it helps
Have a nice time over there
Please rate my answer
Mar 12, 2010 | Audio Players & Recorders
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Earphones right side won't play...
I inserted a drill bit that fits the exact size of the aperture and twisted it around a few turns and it is working better.
Heath Robinson eat your heart out
Jun 07, 2009 | Audio Players & Recorders
The left speaker is not working. only the right speaker is working. can anyone describe how i can open the case and inspect the headphones myself?
If the left earphone is completely deaf, then the problem is the input jack, and the usual solution is just to buy new headphones. I've had this problem with the earphones for my iPod.
Apr 02, 2009 | Panasonic RP-HS103 Consumer Headphones
826 people viewed this question
 Grubhead
Grubhead
