Question about HP Pavilion F50 17" Flat Panel LCD Monitor
How to install the CD-Drive?
I have a Hp Pavilion F50 and my cd-drive won't run when I slide in a disc. It won't read and I'm trying to find a code or something to reinstall the hardware.
    Problem Solver:
  • 19 Answers
The drives laser is probably bad. cheaper to replace the drive
Posted on May 15, 2010
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
I have an HP Pavilion dv6700 Notebook PC with Intel(R) Core(TM)2 Duo CPU T5750. It is using Windows Vista. Sometimes when I turn my laptop on the CD/DZD Drive will show in MyComputer and sometimes it...
Im not an expert on CD drives but I have had this case happen in many times. If it sounds like its starting then randomly stops it sound more of a hardware disk problem. You may want to try reinstalling drivers or getting a new computer.
May 22, 2017 | HP Pavilion DV6700T Notebook
Hp Pavilion Media Center TV m7470n Desktop PC does not read my recovery disc,wrong disc
is ur dvd/cd drive reading other cd/ dvd .if no then the lense of the drive is bad and it needs to be replaced or the cd is bad and has many scratches.
Sep 04, 2009 | HP Pavilion m7470n (ER883AA) PC Desktop
HP 530 laptop. Vista Home Basic OS. 18 months old.
the motor went bad in the drive if its not even trying to spin the disc. The only option at this point is to get the drive replaced.
Sep 04, 2009 | HP Pavilion dv6000z Notebook
Dvd/cd drive issues
This can happen when the disc to which you are trying to write is corrupted, or has been partly used. Try another disc.
Jul 08, 2009 | HP Pavilion zd8000 Notebook
Our hp pavilion 4535 will not read discs
I'm thinking of a couple of solutions:
  1. Auto run as turned off, navigate to your drives (usually in the My Computer icon) and check for your disc drive (usually Drive D:). If it is showing a disc then you can right-click and open to see the contents or double click for an auto-play.
  2. If you open up the drives and don't see a CD ROM drive then it might have gotten dropped some how. In this case you will want to go to the device manager and check to see if the CD ROM drive is listed and if it needs some fixing.
Mar 13, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
DVD Drive not working properly
Try cleaning the drive with a cleaning disc (purchasbale at most electronics stores like Best Buy or Circuit City). If that doesn't get it up and running, it'll need to be replaced.
Jan 29, 2008 | HP Pavilion dv6000z Notebook
My CD/DVD drive needs replacement
IF U GET THAT SAME MODEL IT WORK PROPERLY..
Jan 11, 2008 | HP Pavilion dv4000 Notebook
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Cd rom drive does not work! NEEDS ASSISTANCE!
Magnit can damage your Cd drive, maby it is damaged.
Nov 14, 2007 | HP Pavilion (PN153AAR) PC Desktop
HP Pavilion F50 17" Flat Panel LCD Monitor Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
