Question about Nikon 847 Tripod
Wobbly cameras on quality tripods -- stripped screw mountings?
I have four sturdy tripods for lightweight video cameras -- two are manfrottos with quick release plate. Other two have screw mounting. Been using them for a while and at least two of them have very wobbly connections now. Is it possible to strip the screw mount on the camera? Or is the problem with the quick release plates -- screw mounts. Doesn't matter which camera i put on -- even the lesser used ones -- they are all wobbly. The connection to the tripod itself is solid -- no problem with the camera disengaging even when upside down -- but the actual camera itself wiggles around on connection. Not good for weddings.
  • colvinhooser May 18, 2010
    Just for clarification, when you put any of the cameras on any of the tripods, the cameras attach firmly to the tripod, but move when you pan or tilt the camera?
    Could you please tell me what cameras you are using? Is the camera body plastic or metal?
    Thank you for clarifying your problem for me.
  • Nikon Master
  • 5,412 Answers
Sounds as if the tripod socket in the base of the camera is too shallow for the thread on the QR plate. You can undo the split ring that holds the screw in the plate, and fit a washer beneath it to shorten the protruding screw. What I do is keep a plate permanently attached to each of my cameras and camcorders, so that I do not have to continually remove it to put another camera on.
Posted on Apr 12, 2017
CompuGuy44
  • 432 Answers
SOURCE: Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Posted on Jul 03, 2007
  • 24 Answers
SOURCE: Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Posted on Jan 30, 2009
SOURCE: Removing Tripod head from center post on Manfrotto Modo 785B
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
Posted on Feb 06, 2009
  • 685 Answers
SOURCE: Nikon 70-200mm Tripod Mounting Question
There should be a mount that attaches around the barrel of the lens with a flat part that would allow you to screw that to your quick release plate. The flat part usually have several screw holes so you can mount the quick release plate for or aft for better balance. These mounts are removable so it may have been taken off.
Posted on Nov 27, 2009
  • 17 Answers
SOURCE: I own a photography studio and need to buy bayonet mount rings for all my students' cameras. Where can I buy them in bulk?
Well, I have never needed to purchase my bayonet rings in bulk before; however there is a great website that should have just what you are looking for. I will post the link for you here - hope it helps.
http://www.alibaba.com/showroom/bayonet-adapter-ring.html
Posted on Jul 18, 2012
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
Is there a Carbon fibre small compact with splitter
Carolyn
-If you are looking for a compact light weight (CF) tripod for video...., that is going to be...., stable & durable (for use with a smaller video camera or a DSLR) & with a mid-level spreader...., I have some bad news for you. They do not exist!!!!!
-You can get a number of tripods that meet some of these requirements..., but not all!!!
-No fear....., it is still possible to get a tripod that is small, light, repairable and with a higher weight capacity and better durability than either of the Manfrotto tripods you mentioned..., but they will not use a mid-level spreader!!!
-Questions for you...., the manfrotto #055CXB has a column that terminates with a flat plate & a 3/8-16" thread. The Manfrotto # MTV502AM tripod has a 75mm bowl mount. Do you use a video head with a flat base or with a 'bowl'?
-If your head has a flat base consider looking at CF tripods from brands such as Sirui (#N2204 or #N3204)..., great value tripod from China..., or products from Gitzo or Really Right Stuff...., (superior products...., and your grandkids will be using them..., but pricey)!!!!
-If your head uses a 75mm bowl mount get the Miller #1501 tripod...., stupidly strong and well supported.
-Bottom line..., with light to mid weight cameras, if you go with a good quality spreaderless tripod that uses 'rotary locks' vs 'quick release' locks...., the leg mechanisms are so superior that you will find that you will get less flex than most tripods with spreaders. They will also be smaller, lighter and allow you to shoot far closer to the ground!!!
Go t a shop that has a good selection of quality tripods and test for leg twist..., you will be converted!!! (note: to test this leg flex..., extend the legs & grab hold of (2) of the tubes near the top 'crown' and then try to move the legs to the left then right...., many will exibit significant flex at the joints!!!!
Jun 21, 2013 | Manfrotto Photography
Hi, I have a Manfrotto 525 MVB tripod and I am trying to connect my Canon EW-78E to it but I am not sure how to? Thanks for taking the time to read this and hopefully you can help. Laura.
Sorry your question doesn't make scents the Canon EW-78E is a lens hood and the Manfrotto 525 MVB is a Pro lightweight video tripod there is no way to mount then together.
Mar 04, 2011 | Photography
What's the thread diameter of the bottom mount of the 3130 Manfrotto head?
The hole in the bottom is 3/8 of an inch. the screw on the top plate that holds the camera is a 1/4 inch.
Jan 09, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
Which one is better 055xB or Manfrotto 3021
Manfrotto makes good quality tripods,never had a problem w a Bogen or Manfrotto product
Mar 25, 2010 | Manfrotto Photography
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Attaching head to tripod
video cameras come with a 1/4-20 threaded socket in the.  Make sure the 3066 has this size screw projecting form the place where the camer is attached.  The two Manfrotto should be compatible
The only time fitting together becomes a problem is if you are into the heavy duty professional equipment.
We especially like the Manfrotto fluid heads and have several in our facility.
Nov 01, 2008 | Photography
701RC2 going on 745B sticks
Hey SkipHall,
As in most Manfrotto tripods this tripod should have 3 set screws underneath the head mounting surface. Unscrew these set screws and you should be able to unscrew the current head off the tripod by holding the center column and turning the head counter clockwise. Installation of the new head should be the reverse. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Manfrotto 745MF3 Tripod
Nikon 847 Tripod Logo
201 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
