Question about Yamaha HTR-5840 Receiver
Will not turn on, no sign of life,
Will not turn on no sign of life mains to power supply and fuse ok about 60 volts ac out
  • 311 Answers
Where is this 60V being mesured from?
Posted on May 12, 2010
Laptop is dark; it will not start, and nothing lights up or attempts to work.
could be a fuse of a hd failure
take it in for a diagnosis and quote to fix
Feb 10, 2016 | Computers & Internet
After lightning storm whole system died. Still 12v supply from battery and 18v AC to board but all lights and panels dead. Any advice welcome.
What AC voltage should you have to the board . If it is mains power then something has been fried.
Dec 25, 2014 | AC Cars & Trucks
The generator produce onely 73 volts ac on the 120 volts plug and 146 volts ac on the 220 volts plug . what could be causing this problem
Check all wiring and fuses associated with you voltage regulator if they check ok, find a way to adjust your voltage regulator replace it. Make sure the unit is running at 3600 rpm as well and making 60 hz.
Jul 10, 2011 | Coleman Powermate Premium Plus 6250W...
My DVR 433 H-K does not power up. Already checked the 220V AC power cable. Everything OK with the cable. I suspect it is the fuse in FU01. What do you think ?
If the DVR is dead it could be the primary fuse.Typically its a 1.25Amp fuse.But remember a fuse does not blow with out provocation, there might be a short circuit else ware esp: the regulator chip.
After replacing the fuse turn it on with a 40 to 60 watt incandescent light bulb in series. On turning it on if the bulb remains glows full bright -- indicates a short circuit further up. Most probably the main switch mode supply IC must be at fault.
Jul 06, 2011 | Televison & Video
TV set appears to be 'dead'
Check the power supply capacitors to see if they are bulged.
If they are replace them, this should fix the problem, if not replace the main board.
otherwise replace the power pcb
May 23, 2010 | LG 26LH200C 26 in TV
Tv won't turn on
I assume you do not have any red light showing on the front of the TV to indicate it is receiving power? Again assuming the your mains electric supply is functioning & the fuse in the TV plug is ok, if there are no signs of life & then most likely a fuse in the power supply may have blown. If you have a multimeter you could remove the rear of the TV & check the fuses in the power supply, if these are ok then you will need to check any supply voltages coming from the power board. If one of the fuses are open circuit, check some of the doides or transistors for any short circuits. If you are not comfortable doing this, then it would be advisible to contact a repair service centre.
Jul 28, 2009 | Televison & Video
AC Breaker trips and AC Fan turns slow.
Sounds like you have a bad capacitor for your squirrel cage fan , now as for the a/c unit sounds like you have a direct short in compressor to ground or leg to leg , check all wiring to make sure that it is not grounding out or melted together.
Jul 23, 2009 | Goodman CLQ36AR49 Air Conditioner
No power/RCA ctc187cl
Check for 5 volts present at pins of EEPROM IC. ( 8 pin-center
front) = no 5 volts = Re-check power supply components such as AC in resistor 2.7 Ohm ?....Or 5 volts ok,then suspect EEPROM corrupted........part # 223957 ( install 8-pin socket,then re-plug in original, if that doesn't clear it, plug in
new part) Use pre-programmed after-market replacement,if you
can get it.....Let me know....T.
Oct 30, 2007 | RCA F32450 32" TV
Electricity went out in town, tv won't turn back on.
On this type of problem, the first thing I check is the AC line fuse on the power supply. Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse. If: Then: It checks bad. Replace it. It goes out again. Call a Servicer. It is good. Check for the five volts that goes to the Main PCB. No five volts, change the power suppy (SMPS) Five volts is there, more than likely the Main needs replaced and SMPS. For a Samsung Servicer in your area: 1-800-SAMSUNG
Aug 18, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Dvd player is completely dead.
First thing to check is the power cord with it unpluged. Do you get a resistance there or is it open?? If its no reading at all then the power transformer or fuse or current limiter resistor is open. If you do get a reading then you know your power transformer primary is good. Next measure the AC volts comming from the secondary of the transformer. AC volts? Good! Now Find pin 1 or the end pins on the microprocessor. 5 volts present?? No theres your problem get a schematic and troubleshoot the power supply. Yes 5 volts? Measure the display any volts on it?? Ok im sure by now your gonna say no to one of these and like I said get a schematic and conferm all the voltages are present in the power supply. Most common dead problem in dvd/cd players is the power supply ie transformer,regulator, ic, ect, ect. Good Luck
May 10, 2006 | LG DVD 5183 DVD Player
Yamaha HTR-5840 Receiver Logo
325 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
