Goodman a/c model # CHPF042B2C won't turn on. Can...
Goodman a/c model # CHPF042B2C won't turn on. Can't get fan to turn on either. Any adive on where to start?
  • Dennis Boxerman May 14, 2010
    Turn your t'stat fan switch to "on" and see if indoor blower comes on. Let me know and we can continue.
GOODMAN AIR HANDLER, FAN AND HEAT STRIP COME ONLINE WITHOUT DEMAND. WON'T TURN OFF BY TSTAT
the w wire off thermosta controls heat. eithe bad board or thermostat.
Feb 01, 2013 | Goodman Heating & Cooling
My goodman condensing units fan won't start to turn on its own
Hello, usually this is a sign of a bad capacitor. Replace the capacitor.
May 21, 2012 | Heating & Cooling
What will stop the fan to stop spinning on a goodman ac unit on the outside
If you are wanting to just get it to cut off because it won't do it on it's own, you can turn the a/c breaker off at the breaker box. I have seen alot of blower fan switches go out on older goodman units and the blower stays running all of the time. Get a technician to check it for you. Good luck .
Jun 18, 2011 | Heating & Cooling
I have a Goodman A/C unit model # GSC130361F A and a Evcon
The indoor fan should cycle with the outdoor part, make sure the thermostat is not set to fan "ON" and if the fan is on "AUTO" it could be a wiring issue or a fan relay that is stuck.
May 28, 2010 | Goodman CLQ36AR49 Air Conditioner
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman model 135-5 furnace fan and induce motor run all time even with thermostat off. Theermostat and wire were replace
Is there a thermal Fan/Limit switch in this furnace? If so you may need to tweak the low range setting so it can turn off the blower.
Nov 04, 2009 | Goodman GMS90703BXA Heater
Goodman model cpe30-1ab heat pump fan not turning. Air is coming in. I have a call into the repairman, just want to get a headsup. At one point I saw smoke coming out of the unit.
usually if the fan failed the heater will overheat maybe the smoke you saw was coming from the heater. Let the repairman to repair the fan.
Jun 08, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
