Question about True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F
T49F true freezer thermostat does have a hot + ground or does it not make a dif. Likr other frezzers
  • True Master
  • 1,253 Answers
As a general rule, in ALMOST every case, the thermostat just breaks one side of power. Usually one wire in and one out. I've not seen a double pole, single throw in a True, ever.
Posted on May 14, 2010
Diagram
2 and 4 are power for the timer 1 and 3 are load lines N is defrost termination.
Mar 27, 2014 | True T-49Dt-4 - 2 Sections...
Need wiring diagram for true t49f
true has a service tech hot line
Feb 01, 2014 | True Freezers
Fan is not running in my True T49F Freezer
There is a switch above the door; check you have power from it when closed, then check the evaporator is cold enough as there is a thermistor that stops the fan until it is beginning to freeze. Lastly check the fan blade isn't stuck and the motor is ok.
Jul 02, 2012 | Freezers
Model # t49f 2 dr. freezer unit tripping 20amp
Request a T-49F-RC wiring diagram directly from True.
Nov 20, 2017 | True 49 cu. ft. / 1388 liter Commercial...
We have a true T49F freezer and the evaporator fans are not running. The compressor is running on startup. The coils are cold. But are freezing up. Shouldn't the fan be on, or does the cabinet have to...
Freezers have a sensor that is referred to as a "Fan Delay/Defrost Terminator". It senses the temp during the defrost cycle. Usually, when the evap temp reaches about 50 degrees, there should not be any frost or ice on it. This device terminates the defrost cycle. It also keeps the fans off so warm air is not circulated. When the evap gets to about 20 degress or so, the sensor switches on the evap fans. If the fans are not coming on, either the sensor is bad or the evap is not reaching the proper temp to cause the sensor to turn on the fans.
Hope is helps to clear up some things and point you in a direction as to what might be going on.
Jul 12, 2009 | True 49 cu. ft. / 1388 liter Commercial...
What do you do to convert a T49F freezer to run as a refrigerator and is this feasible?
First of all the unit uses a low temperature compressor which is designed to work on a freezer. Refrigerators use a medium temperature compressor. So most likely it would be over sized for what you are trying to accomplish,
Secondly the evaporator feed device is designed for "low temperature", not "medium temperature", so it would involve resizing the feed device.
May 27, 2009 | True Freezer T49DTG Stainless Steel
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F Logo
140 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Freezer Expert? Answer questions, earn points and help others
