Question about Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 760 powers on but the touchscreen will not work
  • Garmin Master
  • 587 Answers
If the Touch Screen is not working properly, Calibrate the touch screen..
Turn he unit off then on.... Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until calibration screen appears... for on screen instructions
Posted on Oct 27, 2010
2 Suggested Answers
  • 587 Answers
SOURCE: nuvi 760 powers on but the touchscreen will not
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Mar 29, 2013 | Garmin nuvi GPS
Touchscreen not responding. Frozen
Two thing can cause this. If your unit is running firmware version 5.3, this version has a bug where the touchscreen will work for about 5 seconds then the unit will lock up. Updating the unit to version to version 5.4 will fix the problem. More info can be found here:
http://www.sharc.net/discus/messages/6/471.html?1337567850
http://www.sharc.net/discus/messages/6/469.html?1333569932
If you are running firmware version 4.9 or 5.4 and the touchscreen still does not respond, then the touchscreen will need to be replaced. On the Nuvi 7xx, the touchscreen may be soldered to the LCD display, so if you don't have any soldering experience, please have a professional replace the touchscreen. More info can be found here:
Mar 23, 2013 | Garmin Nuvi 760 Car GPS Receiver
My Garnin Nuvi 760 has stopped responding to touch screen. It starts and eventualy opens a map but nothing I touch on the screen will respond.
The problem is probably with touchscreen (a thin film on screen)
You can try order a replacement touchscreen on ebay and replace it yourself
Tip: order a couple of them, they are cheap but extremely fragile
May 19, 2011 | Garmin Nuvi 760 Car GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Apr 25, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 760 ...updating bluetooth firmware
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI
To reset your NUVI , please follow one of these procedures :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
After that you can try again with updating .
PLEASE DON'T FORGET TO RATE !
Apr 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
I am not receiving any sound form my nuvi 760
Have you checked the sound level, or the possiblity that it is muted?
this is common with the 760 since everything is accessed via the touchscreen menu
Mar 27, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
New Nuvi 760 that won't work
Using the PC to charge a Nuvi is not the correct way to charge. Use either the AC wall charger or DC car charger. Many PC USB ports can not supply enough current to charge a Nuvi.
- Jim
Dec 12, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
514 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
