Question about Danby DDW496W Free-Standing Dishwasher
Leaking I've had the dishwasher maybe 2 years at the most.  The plastic windo on the front of it has come off, don't know why.  How can I fix it?  Where can I find the part.  Thank you
  • 1 more comment
  • ddriver Mar 29, 2008
    DDW496W
  • Shab8 Apr 13, 2009
    I have the exact same problem, only the model number of my dishwasher is: DDW396W
    Does anyone has a solution for this and knows where I can get the part?
  • Heather Tanner May 11, 2010
    If you give me the model number, I'll check into it for you.
If you don't mind rigging it. I took the door apart, drilled out the little plastic stand-offs on the clear plastic window, and put some cabinet knob screws with flat rubber washers all the way around the window. I took the door apart and basically replaced the plastic standoffs around the window with the knob screws. Once I tightened them all down (kind of a pain in the ****, I think there were about 20+ screws and nuts) with the gasket on the window in place, there were no leaks. I also put some silicone caulk around the outside of the window (for good measure). It looks kind of rigged, but it worked and it only cost me about $10.00 in materials and about 2 hours in time. I'm not sure how long it will last, but it looks pretty sturdy (almost sturdier than it did new).
Posted on Feb 18, 2010
    Problem Solver:
  • 6 Answers
Easy fix if it is the inside panel unscrew the inside door the screws are on the sides of the door well flip it over and screw it back together and voila .This worked for me and i havnt had a leak since
Posted on Nov 08, 2009
  • 142 Answers
Common problem on these...
I had the same thing happen to mine and I just contacted AP Wagner (http://www.apwagner.com/)
1-888-279-2463 (in the USA) and they located and sent me the replacement part for it. The window does not come separate, you have to buy the inside panel for the door as an assembly.
Posted on Apr 10, 2008
  • 52 Answers
Sorry, I have looked all over and can't find it anywhere. Good luck with this one.
Posted on Apr 04, 2008
Bush dishwasher DW5FIIS front screen leaking
Contact Bush directly to find out what needs to be done.
Mar 14, 2014 | Bush DW5F 22 in. Dishwasher
Miele G2020 leaking 2 spots help
please follow this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.f3a0b0dc-c8b0-4678-bccb-f94392039827.gif
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the tow kick and maybe the front panel to inspect.
Jun 14, 2013 | Miele Dishwashers
Thermal fuse
http://www.partselect.com/MultiModels.aspx?ModelNum=KUDS35FXSS&SearchTerm=fuse&RefineSearch=0
Maybe this link will help
Jan 29, 2013 | KitchenAid KUDS35FXSS Dishwasher
Dishwasher is leaking out of the front right bottom corner. It spurts out while it is running. I took the front panel off and could see that where it is coming from but dont know why it is all of a sudden...
most of the time when it leaks from the front door it is going to be from a corner. most every time the front door gasket is replaced to solve the problem. I have found that the gasket on my dishwasher last about 2 years before needing replaced. I clean the white hard scale that builds up on gasket frequently
Jun 17, 2009 | Dishwashers
Maytag Dishwasher 2 years old leaking
open the door of the dishwasher and check the seal. It may have just gotten worked out of place or it could be deteriorated enough that you will need to replace it.
Dec 31, 2008 | Dishwashers
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore dishwasher
just above that switch is the float. you are having an oversudsing issue or the switch is not activating correctly. take the float assm apart and clean it up. then use a little less detergent and let me know if this solvs the problem.
Nov 01, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Leaking
That would be bad news. That plastic thing is the pump, and a bad seal means motor / pump replacement or a new dishwasher. Average life of a dishwasher is about 9 years.
Sep 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Danby DDW496W Free-Standing Dishwasher Logo
258 people viewed this question
Top Danby Dishwashers Experts
Mike Cairns
Mike Cairns
jeff5may32
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
