Question about Plumbing
How should an inline valve under the kitchen sink be installed?
  • 623 Answers
If you mean to turn off the water to the faucets, they should be installed under the sink where you can get at them. Usually they are put right on the end of the supply pipes coming up from the cellar.
Posted on May 13, 2010
Replace check valve kitchenaid dual drawer dishwasher
look under the sink for the valve its huge an inline with the waste tube
if not then its here
https://www.youtube.com/watch?v=rOio5HaWeFU
Aug 17, 2014 | KitchenAid KUDD03DTSS DUAL DRAWER...
Hot water doesn't work
Does any water come out of the faucet when turned to hot? If not, you may have disconnected the fautet line from the valve and attached the dishwasher line. You can check this by looking under the sink and making sure all lines are connected to valves.
If everything is connected, you may have dislodged some mineral buildup and it is blocking your hot water line to the faucet. You'll have to remove the line and clean it out.
Mar 02, 2014 | Home
Kitchen faucet
You will need a basen wrench ( a special wrench to tighten nuts that secure faucet to sink) and open end wrenches. First shut off both hot and cold water valves. Using open end wrench, disconnect hoses from valves. Now, you must loosen both nuts (under the sink towards back wall) Using the basen wrench. After removing nuts, lift faucet up
Jan 09, 2014 | Plumbing
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
Are whole house inline water filtration systems expensive?
House filtration systems are pretty pricey they run in the several hundreds dollars, and then replacement filters are in closer to $20 and they only last a few months. If you don't need a filter on every faucet you can install individual filters under the sinks in your kitchen.
Sep 10, 2013 | Water Dispensing & Filtration
The kitchen sink faucet is clogged
If it just the hot or just the cold then it will be the shutoff valve not the faucet. replace the valve/s under the sink Try checking the screen in the head of the faucet for sand. If it does not have a screen(some dont) then it will have a restrictor usually green in color that may have debris inside of it.
Jan 06, 2013 | Kohler K-692-VS Clairette kitchen sink...
I replaced the kitchen sink and hooked everything up, I have water pressure to the faucet but when I turn on the water it just drips out. what's wrong here
Check to see that the cutoff valves under the sink are fully open. Also be sure that any shipping plugs or caps in the lines were removed prior to installation.
Apr 15, 2010 | Delta Model 300: Classic Single Handle...
Water drains slowly from newly-installed kitchen sink and gurgles as the last drops go down the drain
sounds like you have a partial blockage in wall pipe.take of p trap and snake pipe in wall as far as you can.
May 09, 2009 | Home
How to remove a cast iron kitchen sink installed
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Len
Feb 22, 2009 | Eljer 212-1088-00 White Dumount Double...
Plumbing Logo
63 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
