Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
HLP 5685W Thank you by the way for the sequence of events when my DLP comes on. My Fan does come on but the light wheel never does spin up...I have not had a lot of luck finding parts for this TV, so I will probably part it out...what a shame it is a very nice looking TV Thanks again, SODAK
  • Samsung Master
  • 8,617 Answers
I have alot of access to samsung DLP parts if you need anything. The other site where I am a repair tech has a great DLP training manual for the sanmsung DLP units if you want I will post a link cause they provide free tech support to help you diagnose and repair your set.
Posted on Mar 29, 2008
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
Lamp will not turn on. I have (2) PJ458D DLP projectors. I took the lamp out of the projector that is not working and placed it in the other projector and everything worked fine. When I press the on off...
It sounds like an internal problem. How long have you owned the projector? How long have you been experiencing this issue? Once I have more information I can assist you further.
Thanks,
Lee
Sep 23, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
Have a HLP 4663W... Picture fine but a loud whine upon start up that used to go away after about 5 minutes - but now is persistent. Someone had told me that the fan may have dust, but after doing some...
definately sounds like a color wheel, You can tell by listening to where the sound is coming from if its coming from the right side when looking in the rearabout six inches in from the left side in the middle of the light engine is where the color wheel and housing are located. the housing is held in with two screws and then unplug the 2 wire cables. You can get the replacement color wheel from www.tvrepairworld.com which has instructions.
Jul 19, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP hlp5063wx/xaa - Cycles through the warm up 2 times but does not turn on, then 3 lights flash on the front (2 green, 1 red) Bulb is new and looks good, fans seem to be spinning freely. Any...
If your having the "3 light" problem it could be an indication of a bad lamp however if there is a buzzing or a grinding sound it could be one of two moving parts. The color wheel or the cooling fan. I would go the cheaper route and replace the color wheel first since you say the fan is spinning. The thing is the lamp will not turn on if there is a problem with one of the other two parts. The motor on the cooling fan is too small for such a big fan so I would definately try it next. It's a big problem with the DLP tvs. good luck!
Feb 14, 2011 | Samsung Televison & Video
I have an RCA Scenium DLP 50 TV. The TV started making a loud noise (like a computer fan) going out. The noise would go away when we powered off the unit and the bulb shut off. Eventually there was no...
yes ... you could have a color wheel problem.. this set get color from a spinning wheel called a color wheel.. when you unplug this and plug this back in you should hear a whining motor sound. During the "bootup" sequence this motor spins this wheel to test to see if it reaches speed. This is a motor that moves and anything that moves eventally dos not. i see this problem often in the shop and if it is the problem there not all that difficult repair. the hardest part is finding the color wheel
Oct 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP TV makes noise even tho its not on.
from your description sound like you might have a stalling color wheel. the color wheel on a dlp is what provides the color. it is a spinning disk of different colored glass. that must reach certain speed for the tv to operate. and like all moving parts eventally break, and need replaced. you may be able to replace this if your tecnically inclined but i recommend a tech. it may need be setup
Jan 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
My DLP TV wont turn on.
As part of the power up sequence on the Samsung HLP-4336W the lamp isn't turned until timing pulses are detected from the color wheel. The color wheel motor is powered through the flat brown four conductor ribbon cable and the timing pulses are detected over the the three conductor ribbon table.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
493 people viewed this question
Jerry Greenberg
Jerry Greenberg
