Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Worked not it doesnt
My wd passport ext drive....has been working since christmas.....used on my laptop and my desk top....goe to use it today and it says that device is malfunctioning and wont recognize it....using proper cord and led light is lit up and disk is spinning please help...christmas and easter pics on it?
  • pbss Apr 17, 2008
    My drive was unpluged last night and left in the same place never damaged or dropped always sits on my desk. Has light on strong and have tried 3 different cords and other computers. The WD icon will not show up on the desktops. I am a photographer and have several weddings and sports events on there that i cant retake and have been paid for. Any possiblility I can get this to come up?
  • firepper red May 11, 2010
    Was the drive dropped? Do you have the double cable (has 2 usb connections... one for power and one for data)? If the drive is not getting enough power it will malfunction. WD will send you a free dual connection cable if you call them and tell them it is not working on your computer.
    If the drive is damaged in anyway then it will be very difficult to get your pictures off the drive. Try it on another computer and see if that helps.
    Best of luck to you.
I have had the same problem with 2 passpoet drives. They work, then they stop
Posted on Apr 12, 2008
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
My computer does not recognize WD Passport WD2500XMS-00
I use a USB extender cable so I do not have to get down on the ground and plug stuff into my USB ports behind my computer. Everything that I own works through this cable except the WD passport drive. (It is a 2.0 USB cable at that so that is not the issue, plus 1.0 should theoretically still work, just not at 2.0 speeds)
SO...I tried to plug it directly into the USB port on the back of my computer and it worked instantly.
Other people have reported a fix after finding that their cable was loose. This USB cable that comes with the drive seems to be picky for some reason. Perhaps these are faulty cables somehow. Hopefully this will help some people.
lefteris from greece
Mar 26, 2009 | Computers & Internet
320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
Jan 29, 2009 | Western Digital Passport WDXML800UE...
WD Passport Elite 320 - won't install autobackup launcher
I just spoke to WD support...here is how to solve your problem:( I had the same problem and it works great now)
1. Connect your WD ext. drive.
2. Click open Computer.
3. Double click open the WD blue icon.
4. Double click open WD_Windows Tools.
5. Double click open WD drive manager.
6. Double click open the Setup icon for Vista 64 (the other icon
is for x86 windows)
run the setup and it will take care of your problem. enjoy!
Dec 01, 2008 | Western Digital Passport WDXML800UE...
My wd 12o gb ext hard drive not recoginized by my computer
This problem often happens because of the cable, try to move the cable near the connector of your drive. by this time access the devive manager, and check if there is changes in the list while you change cable's position, if so, your cable is defect.
Nov 23, 2008 | Western Digital Passport WDXML800UE...
My computor switches off the moment i plug in the wd passport.
Probably a power issue. Your new computer has less extra power capacity and the external drive is pulling from the USB port power.
What you need is a USB hub with an AC adapter that powers the hub and any devices that are connected to it from the external AC power adapter and NOT from the USB bus. In other words look for an external power adapter that plugs into the wall as well as into the USB port. Don't get a recharger for an iPOD as that will not do you any good. And don't get a hub that says "powered" or "external power" that does not have an AC power adapter because it is still sucking power off of the USB port.
Try shopping for a D-Link DUB-H4 High Speed USB 2.0 4-Port Hub. It is a good choice if you are not going to plug any USB 1.1 devices into it. Read the reviews for any device you choose.
Oct 26, 2008 | Western Digital Passport WDXML800UE...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
149 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
