Question about Kenmore 63942 Dryer
Dryer will not stay running
Knemore Elite Gas Dryer When push the start button dryer tries to start up but will not stay running unless you continue to hold the start button in. No unusual sounds such as belts worn or drum off balance. Checked vent that's clear. Checked door button (holding it in while attempting to start) no change with that either; dryer still shuts off when release start button.
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryerDryer will not stay running - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
2 Suggested Answers
  • 20 Answers
SOURCE: Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Posted on Apr 21, 2010
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
I have a kenmore elite gas dryer... i can push the button to start the dryer and it will start turning but will not continue once depressing the button...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 23, 2010 | Kenmore Dryers
I have a kenmore elite gas dryer model # 70992990 <And when i push the start button and let off it wont stay running! Can you help?
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 16, 2010 | Kenmore Dryers
Apr 21, 2010 | Kenmore 63942 Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore 63942 Dryer Logo
359 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
