Question about Vizio VF550M 55 in. LCD HDTV
My Vizio Tv volume does not work properly. When its at volume 100 it sounds like volume 50. What could be the problem? My question is how can I fix it? Let me know...
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Posted on Jun 29, 2010
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
How to program a vizio tv without a remote vizio
Upon first start you should be prompted. If not, you will find a series of buttons on the TV itself; power,channel up down, volume up/down, input and menu. Hit the menu button and the menu will pop up. Scroll up and down with channel button, select and controls are the volume. either that or you can get a Samsung phone that has an app built into it called watch on, which has a universal remote that works for virtually everything. Happy surfing.
Mar 05, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
Switching av1 av2
If the TV is not working well and you don't want to take it in for repair, then a band aide would be to get a sound bar ~$50 and use that for sound. You may have to get an AV selector box if you have more than one playback unit.
Oct 31, 2013 | Vizio Televison & Video
Vizio TV won't work. We get sound but picture is like distorted and now it won't show video
There are lots of common problems with flat screens that result in those symptoms. Some fixes are super easy and cost $.35 haha and others can cost hundreds not to mention if your doing it your self or not factor in labor. Lots of people sell tv s like that from $50 to $100 bucks and they sell quick! Hell I'd buy it if I had the chance. Could use parts or god forbid find an easy solution ( rare :( )
Mar 13, 2013 | Televison & Video
Check its speaker. If it is OK, check and replace damaged component/s on it audio output board, or replace the board as card basis.
Oct 20, 2012 | Vizio VF550M 55 in. LCD HDTV
Volume is on 100 and it sounds its on 50
First of all ensure that this problem is not from the input device, by changing it to some other like a DVD player to rule that out. Then look for any loose contacts in RC jacks, sockets and cables.
Aug 16, 2012 | Vizio M550NV 55 in LCD HDTV
Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Dec 13, 2010 | Vizio Televison & Video
I have a new vizio 37", just got it, On some stations the volume is so low, I can't hear it. I have cable tv, the volume on the cable box is way up where it says sterio;when the volume is on 100 % it still...
On remote hit tv button hold set up until it flashes twice. Hit 11758 it will flash 4 times hit set up to lock. Now hit tv button and the volume should work on set.. Hope that works
Jan 30, 2010 | Vizio L37 Television
Missing power cord
HELLO AND NO YOUR AMP SUPPLY IS'NT THE RIGHT AMOUNT YOUR CORD ONLY SUPPLIES 2.5 AND YOUR T.V. CALLS FOR 5.2 IT'LL RUN YOUR T.V. BUT THE REASON IT WONT WORK IS BECAUSE YOUR T.V. WILL PULL 5.2 AMPS AND YOUR CORD IS ONLY RATED FOR 2.5 IN TIME THE CORD WILL BURN OUT OR GET HOT AND CAUSE A POSSABLE FIRE.
May 03, 2009 | Televison & Video
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Vizio VF550M 55 in. LCD HDTV Logo
5,373 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
