Question about Sony KDF-E55A20 55 in. LCD Television
Red Light Flashing 6 times
The TV was on, working just fine, I was out of the room for a few minutes, came back in and the screen was out. I turned off, unplugged, then plugged back in. Just after the green power light flashes a couple times (as it normally does before the screen comes on), the power light flashes 6 times continuously. turn tv on no picture or sound and red power light flashes 6 times with a three minute delay and flashes 6 times.This code continues until you power off. I have changed the bulb.I have bipast the surge protector and plugged to wll for power
  • 4 more comments
  • wifeneedstv Mar 29, 2008
    this is wifeneedstv where is the fuse located.For some reason I lost communication with you
  • Anonymous Mar 20, 2014
    the red light comes on but no power showes up on the screen
    red light flashes but no power appears to go to the screen
  • Anonymous Mar 24, 2014
    if tv stays plugged in it contnues to do nothing but click and the red light behind the digital audio out (optical) door contiues to flash and nothing else works
    if the tv staYS PLUGGED IN----+
    MB?lA
    l;dklfjgjkhj;dfgl'
    k;]
    *963./8520
  • Anonymous Mar 28, 2014
    blue light is on for power but no sound or picture some times screen flashes white
  • Anonymous Mar 30, 2014
    have a niko sv3206 plug power cord in red light starts flashing immediatly
    Champion:
  • 208 Answers
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
  • Anonymous Mar 29, 2008
    I was not in the chat, I just saw your post on fixya site. The fuse is mounted on the front of the lamp cage with long leads that come from the lamp cage up to the large wire harness on the back of unit. There the two leads (either both black, or one black and one gray) with a plug.
SOURCE:
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
This just happened to our TV as well. TV was working, we left the room for a few minutes, and when we came back it was off and we couldn't get it to come back on. Green light flashes for several minutes...
try unplugging the tv for a few minutes and see if that does it. if not sometimes there is a reset button on the back. there could be dust inside the back cover that is also shorting out...last resort though. Good luck1
Dec 06, 2009 | Televison & Video
My Samsung hcn4226w won't stay on.
There are many protective circuits inside the set that will shut it down if a problem is detected. It sounds like there are intermittant detections of problems and the "restart" temporarily clears the problem. If the unit is no longer under warranty, open up the back with the set unplugged and try reseating all of the boards and connectors. The trip may have jared a few things loose. Update this with the results.
Thanks,
Dan
Aug 20, 2009 | Samsung HCN4226W 42" Rear Projection...
Black Screen, Audio only , TV will not turn off
back light out,panel defective.no fuse will correct your problem.panel is bad.
Aug 19, 2009 | V, Inc. Vizio P50HD Plasma Television
Phillips flat screen LCD will not turn back on?
Please the volume suddenly went out on my samsung s4223 42 inch screen i cant seeem to get any sound! Can u give me some clues as to what I can look at...I dont think the speaker blew and the picture is fine...
Please help
Aug 03, 2008 | Televison & Video
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
No picture, sound, or response from button on a Samsung DLP TV
Same Same Here - SAMSUNG SUCKS!!! One day we lazy Americans will learn not to outsource so much and get back to good ole American Made.
May 28, 2008 | Televison & Video
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Sony KDF-E55A20 55 in. LCD Television Logo
1,276 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
