Question about ViewSonic VX2235WM Monitor
Screen is black
Our screen is black the power light is on and we can here that the computer is working it seems to be the screen. If we turn the screen off then on it comes up with no signal. What is the problem???
  • 11,361 Answers
Please look for bad caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Common problem with all LCD monitors.
Make sure to use good caps such as PANASONIC FM or FC series from Digikey.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 12, 2010
Black screen on startup for macbook bro
It may be a problem with your light behind the screen or the driver's that produce the energy to light it up. Sounds like a hardware problem to me.
Mar 05, 2014 | Apple MacBook Pro 15-inch Mid 2009 2.53GHz...
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Blank screen
Take a flashlight and shine it on the screen. If you can see an image, you probably need to replace the power inverter board. It supplies power to the backlight.
Jan 23, 2010 | Toshiba Satellite M305D Notebook
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
ViewSonic VX2235WM Monitor Logo
199 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
