Question about Maytag Atlantis MDE7400AY Electric Dryer
WheN I pull the knob out to start it doesn't start
  • 1,305 Answers
There is a door switch that not only turns on the light in the dryer, but also completes the circuit so the machine can start. Check the switch by pushing the button on the switch with your finger and listen for a positive clicking sound. If there isn't a click, the switch is most likely the cause and is fairly easy to replace by pulling the front cover off the dryer.
Posted on May 12, 2010
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
I have a Maytag dependable care quiet pack 2 speed super capacity 9 cycle Model No. LAT9416AAE
It is possible that you need a new timer which is a part number: 22003362 and is usually about $75-$100 but it is also possible that one of the components of the knob is not functioning properly. The best bet is to take the knob apart (make sure the arrow points to a wash cycle first) and then pull up on the time timer shaft itself. If the washer starts then you know its one of the components of the knob that when bad. If it doesn't then you know you need a timer.
Nov 16, 2012 | Maytag Dependable Care LAT9706
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Dryers
The start knob doesn't engage when pulled. Do I just need to replace the knob assembly? Is it difficult?
Take the knob off and try using pliers to pull the stem. Don't pull any harder than you would with the knob. If it works, you just need a knob. If it still won't engage, you need a timer.
Dec 07, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Dryer knob cannot pull to start
The catch for the knob has been damaged. You'll need to replace the timer
May 05, 2009 | Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Maytag Atlantis MDE7400AY Electric Dryer Logo
341 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
