Question about RCA R52WM24 52" HDTV Projection Television
AUTO CONVERGENCE DOES NOT SHOW IN SETUP RED BLUE
Auto convergence does not show in setup red blue green out of focus
  • RCA Master
  • 8,617 Answers
The repair kit is available from www.tvrepairworld.com its called the ITC222 and ITC222 convergence option missing repair kit. The kit contains the parts and the CD with instructions.
Posted on May 14, 2010
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
The red color will not lined up with the green and blue, its way to much red, can you help
You need to set the Convergence of the TV set.
Some TV sets have a Magic Focus on the front panel, if yours has this press it with the TV on.
If your TV does not have the Magic Focus button, go in to the menu and there should be an Advanced Setup option ether in the main menu or under the video setup menu. Then find set Convergence. You will need to be directly in front of the TV set and at the normal distance away (where you usually view it from) use the arrows on the remote to move the color i.e. green, red, blue so that it disappears behind the white + (cross). this must be done for all of the mentioned colors.
Feb 05, 2010 | JVC AV-48WP30 48" Rear Projection...
How do i start auto convergence
Press your MENU button on the remote. Move to SETUP and press OK. Then choose Convergence. You should wait until your TV has been on for at least 1 hour before you run the auto convergence. Once the auto convergence has run, you can do your own fine tuning. There will be separate adjustments for Red convergence and Blue convergence. You will use the arrow keys to line up two sets of lines. The instructions will show up on the screen. Good luck, and I hope this takes care of your issue.
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Picture has 3 images, all different colors (red-blue-green) screen looks concave in the middle top & bottom
This is what is known as convergence..(very common)... first question DO you have the "CONVERGENcE" option in your setup menu?.... if you dont there may be a special fuse issue... if not then more than likely it is what is known as convergence power supply issue. you have complete loss of convergence?
Jun 01, 2008 | RCA D52W19 52" Rear Projection Television
How can I do Auto Convergence on my 52" TV
The auto convergence should run automatically when activated, If it doesnt you will need to replace the convergence board.
May 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TOSHIBA REAR PROJECTION TV 42H81
you have a convergence problem that will require the replacement of the convergence amp ics.
Nov 29, 2007 | Toshiba 51H83 51" Rear Projection...
Convergence problem
Blue convergence IC is bad! Blue CRT OK!
Required for repair---pull chassis,replace STK392-110 X 2.
Re-assemble,adjust convergence as needed.
Oct 12, 2007 | Toshiba 57H82 57" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
184 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
