Question about Troy Bilt Tb70ss Gas Trimmer
Shaft disengages and trimmer head stops spinning. Seems to be disengaging at coupling were attachments hook up. Shaft slides back and forth and when I turn trimmer off and jiggle trimmer then start it back up it works for a while then stops.
    Problem Solver:
  • 7 Answers
Something wrong with your cintrifical force clutch . it is problably set too loose so the the shaft wont engage
Posted on May 12, 2010
Ryobi trimmer Rlt30CES head slow down under revs
Sounds like a drive shaft/clutch type problem, I do not know the machine but suspect it uses a flexible shaft to the head has this union worn out or at the motor end there would be some kind of clutch which would leave the motor spinning on tick over (not the head) then engage on rev up. Perhaps this is faulty or has oil on it, could be its flexible shaft has got a worn end.
On my old B&D it throws a sprung disc out under centrifugal force to engage with its drive shaft coupler which at low revs the springs "win" to disengage it.
Its head end is easier first to check by removal of its line holder after that things are more complex with mine four screws remove what I call its nose cone to get into the clutch area.
If there is a wear issue run it at a gentle speed dabbing its head into some grass you may find the motor spins on but its head stops which will confirm the above.
Hope this helps..........
Apr 28, 2017 | Ryobi Garden
Does trimmer head spin at idle
this is a hard question ,ill start with the text book answer , NO the idle should be low enough to disengage the clutch and remove power from head . but in reality this always is not possible , me I judge a clutch and engine idle % to be working correct if I can put cutting head on ground and not have it take off with throttle closed off
May 26, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
My ryobi gas trimmer will not spin when running
sounds like the drive cable inside the shaft has disengaged from the motor or from the spool. possibly a broken drive cable.
NOTE to Classifiers: this is NOT a tiller or cultivator
Jul 01, 2014 | Garden
Head not spinning shaft cable is.
place a screw driver in the slot the drive goes into and hold the trimmer head feel the head
Aug 16, 2012 | Troy-Bilt Troybilt Mtd String Trimmer...
Weed eater wt255cls brand new starts but the trimming head is not spinning? seems to be in neutral?
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 08, 2012 | Garden
The trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
May 30, 2009 | Homelite Mighty Lite Lawn Trimmer
It won't rotate
It is slipping because the clutch is worn. The only cure is a new one.
Sep 06, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Troy Bilt Tb70ss Gas Trimmer Logo
930 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
