Question about Kenmore 16225 Grill
Knob removal hello .. i was assembling a new grill ( an inexpensive one). I attached the knob control upside down ( on is off and off is on ...). All i have to do is to remove the knob and unscrew the control and attach in the right direction ... I dont know how to remove the knob .. should i just use a screw driver to pop the knob out ? Any help is appreciated .. Thanks RT
  • Anonymous Mar 31, 2014
    How to remove old knobs without breaking them
  • 32 Answers
Yes. it slides on a off with a little pressure.
Posted on Apr 06, 2008
Grill worked fine for almost a year but I recently used charcoal following the directions in the manual (and it worked great). However since using it (& it is long gone), if I turn grill on high,...
Kathleen, the ash and debris left from the charcoal clogged the burners and caused the flames to shoot back thru the venturi valves, which is causing the flames to reach the control knobs. For the most part. I would suspect that the control panel, the electronic ignition, control knobs, the gas manifold for the burners and the burners are now completely shot.
Now, you're at the stage of determining is it worth it, to replace all the parts (if you can find them) and repair the grill. Since you didn't mention who the manufacturer of the grill is and how long you've had it. I have no way to tell how much it's worth. But, if it were me, and the grill is at least 5 years old and it originally cost $600.00 or less, I'd seriously consider replacing the gas grill with a new one. And if you want to do some charcoal grilling, get a separate inexpensive charcoal grill and take good care of it. During the weekday evenings when you don;t have time for charcoal grill to preheat, use the gas grill. On weekends, use the charcoal grill if you like.
Hope this helped answer your question and ultimately help you make the right decision.
Apr 26, 2011 | Vidalia Grilling
Sear knob will not stay on (very loose fit). Other knobs seem tighter fit. The grill is brand new -- thus disappointed by post assembly quality control.
Pull the knob of of the sear burner valve shaft and check to see if it is melted on the inside, if it is, it will fit loose and needs to be replaced.
Dec 30, 2009 | Weber Summit S-470 Propane Grill
I need to know how to do the heater core in a chevy s10 p/u
  1. Disconnect the negative battery cable.
  2. Drain the engine cooling system.
  3. Remove or disconnect the following:
    • Heater hoses from the heater core
  4. Remove the instrument panel as follows:
    • Disable the air bag system.
    • Set the parking brake and block the wheels.
    • Disconnect the parking brake release cable from the parking brake lever.
    • Unfasten the screws that retain the DLC instrument panel left side sound insulator. Feed the DLC through the hole in the sound insulator.
    • Unfasten the right side sound insulator panel screws and remove the panel.
    • Unfasten the screws that attach the instrument panel left side sound insulator to the knee bolster and cowl panel.
    • Unfasten the nut that attaches the left side sound insulator to the accelerator pedal bracket.
    • Unplug the remote control door lock receiver module electrical connector.
    • Remove the door lock receiver module from the left side sound insulator. Remove the left side sound insulator.
    • Unfasten the screws that attach the instrument panel center sound insulator to the knee bolster, instrument panel, heater assembly and floor duct.
    • Remove the center sound insulator.
    • Unfasten the screws that attach the courtesy lamp to the knee bolster.
    • Unfasten the screws that attach the knee bolster to the instrument panel.
    • Disconnect the lap cooler duct from the knee bolster.
    • Unplug the lighter electrical connection and remove the knee bolster.
    • Unfasten the steering column-to-instrument panel nuts and lower the column.
    • Unfasten the screws that attach the instrument panel accessory trim plate to the instrument panel.
    • Remove the trim plate and unplug all necessary electrical connection.
    • Remove the heater and/or air conditioning control assembly.
    • Remove the radio and the storage compartment assembly (if equipped).
    • If necessary, remove the instrument cluster.
    • Unfasten the left and right instrument panel pivot bolts and the panel lower support bolt.
    • Unfasten the speaker grilles retaining screws and remove the speaker grilles.
    • Remove the windshield defroster grille using a flat-bladed prytool. Start at one end of the grille and work your way down the grille.
    • Unfasten the 4 instrument panel upper support screws.
    • Tag and unplug all necessary electrical connections.
    • Remove the instrument panel from the vehicle.
  5. Remove or disconnect the following:
    • Air inlet assembly, if equipped
    • Vacuum hoses
    • Heater assembly studs, from inside the engine compartment
    • Blower motor resistor
    • From inside the heater case assembly, the stud; the stud is located behind the blower motor resistor
    • Heater assembly-to-chassis screws
    • Heater assembly from the vehicle
    • Access cover screws and cover from the heater assembly
    • Heater core from the heater case assembly
View of the heater case assembly
View of the heater case cover
View of the heater core
Oct 19, 2009 | 2000 Chevrolet S-10
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Mar 19, 2009 | Grilling
Pulled every thing apart to get the heater core out and I can't figure out how to get it out. What am I doing wrong??????
  1. Drain the engine cooling system.
  2. Remove or disconnect the following:
    • Negative battery cable
  3. Remove the instrument panel as follows:
    1. Disable the air bag system.
    2. Set the parking brake and block the wheels.
    3. Disconnect the parking brake release cable from the parking brake lever.
    4. Unfasten the screws that retain the DLC instrument panel left side sound insulator. Feed the DLC through the hole in the sound insulator.
    5. Unfasten the right side sound insulator panel screws and remove the panel.
    6. Unfasten the screws that attach the instrument panel left side sound insulator to the knee bolster and cowl panel.
    7. Unfasten the nut that attaches the left side sound insulator to the accelerator pedal bracket.
    8. Unplug the remote control door lock receiver module electrical connector.
    9. Remove the door lock receiver module from the left side sound insulator. Remove the left side sound insulator.
    10. Unfasten the screws that attach the instrument panel center sound insulator to the knee bolster, instrument panel, heater assembly and floor duct.
    11. Remove the center sound insulator.
    12. Unfasten the screws that attach the courtesy lamp to the knee bolster.
    13. Unfasten the screws that attach the knee bolster to the instrument panel.
    14. Disconnect the lap cooler duct from the knee bolster.
    15. Unplug the lighter electrical connection and remove the knee bolster.
    16. Unfasten the steering column-to-instrument panel nuts and lower the column.
    17. Unfasten the screws that attach the instrument panel accessory trim plate to the instrument panel.
    18. Remove the trim plate and unplug all necessary electrical connection.
    19. Remove the heater and/or air conditioning control assembly.
    20. Remove the radio and the storage compartment assembly (if equipped).
    21. If necessary, remove the instrument cluster.
    22. Unfasten the left and right instrument panel pivot bolts and the panel lower support bolt.
    23. Unfasten the speaker grilles retaining screws and remove the speaker grilles.
    24. Remove the windshield defroster grille using a flat-bladed prytool. Start at one end of the grille and work your way down the grille.
    25. Unfasten the 4 instrument panel upper support screws.
    26. Tag and unplug all necessary electrical connections.
    27. Remove the instrument panel from the vehicle.
  4. Remove or disconnect the following:
    • Vacuum hoses
    • Stud from inside the heater case assembly; the stud is located behind the blower motor resistor
Feb 19, 2009 | 2001 GMC Jimmy
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Kenmore 16225 Grill Logo
233 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
