Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Weird smell first use
Is there any reason that you would get a weird gasy type smell the first time you're using the oven?  I read through the manual and there was nothing specially noted concerning the first use of the stove but we are pre-heating and cannot get over the smell.
Its rather subtle but, its still there ;)
Also, the stove is on, the cooktop works fine, but the damn lights on the inside do not work at all......  This was not another missing install step was it?
Thanks for the help!
  • 639 Answers
STOP YOU MAY HAVE A GAS LEAK!!
DO NOT TURN IT ON AGAIN TILL YOU HAVE SERVICE OR CALL THE GAS COMPANY AND THEY WILL COME OUT RIGHT AWAY TO CHECK IT!
SMELL GAS ALWAYS CALL THE GAS CO.FIRST THING!
GOD FORBID!!
Neil
Please give me a solution rating here at fixya.com
Posted on Aug 24, 2008
Why does my fan oven smell of fumes when switched on
could be a couple of reasons. if it is a new oven, it will smell for the first few times, they all do. If you have cleaned the oven recently it could be the residue burning off.
Oct 17, 2014 | Microwave Ovens
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
How to set up for self cleaning oven
The first time you do a self clean it does smell weird and you setthe time to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven
Sep 22, 2009 | Dishwashers
Self clean for 4 hours -- do i need to leave my apt?
The first time you do a self clean it does smell weird and you do not need to do it for 4 hours change the setting to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven.
Cheers
Al
Sep 11, 2009 | Bosch Ovens
Brand new gas stove. When oven is turned on there is a heavily gas smell.
There have been reports of gas ranges which have been installed with no leveling legs. (due to various reasons, like a new floor installed, but the counter tops stayed in the same place, so the range surface would be higher than the counter top if the legs were installed) In some cases, this results in an insufficient amount of combustion air for the oven. To test this, put the range up on a set of 3/4 inch or so blocks and try the oven again. Let me know how that went. Thanks.
Apr 29, 2009 | Kitchen Ranges
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Co smell during oven use
What you are smelling is the protective grease against rust or corrosion that came originally with your oven. the odor is normal if you are just purchase the oven.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
197 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
