Question about Hobart AM14-253 Free-standing Dishwasher
I have a Hobart AM-14 dishwasher that won't operate in automatic but will work on manual. The switch works! I changed the float/level sensor...any ideas what might be wrong? The next step is changing the card.
  • 20 Answers
Ok, Dont forget to disconnect the power before touching anything electrical. especially around water!. Much of what I've added here will take care of most motor issues and doesnt necessarilly pertain to the problem that this guy had. I just added the extra tips for those of you having similar problems with am12 or am14 dishwashers.
Always check and repair burnt wires if needed.
1st: With the power on! Look at the main control board inside control panel door. make sure the Hot Motor Light is Not illuminated. If it is, you have a hot motor or one of the two sensors in the motor is open(bad, no resistance). With the power off, Motor Sensors can be bypassed with 1000ohm resistor from Radio Shack. Hobart does sell the sensors (motor thermistors). They have to be packed into the motor windings by a motor specialist to replace them. Otherwise just bypass the one that is bad by rigging resistor into the plug where the "sensors" wiring harness plugs into the board or rig it into the motor side of harness and tape it up so it doesn't short out to anything. Note: A bad contactor on 3 phase units can cause over heating(usually you will hear motor hum). On single phase motors, a bad start switch(inside motor) or capacitor(mounted on motor)
will stall the motor and overheat(again you may hear it hum, usually). IF YOUR MOTOR HUMS, The FIRST thing to check is to make sure the motor spins freely. take a screw driver or something similar and try to spin the motor by pushing on the plastic fan visible thru motor vents. If it does not spin freely, check to make sure there is no silverware or a scratch pad stuck in suction side of pump, inside dishwasher tank. Its tough to get to, you may feel it with your fingers or use a small mirror and flash light to see up under the inlet hood thingy. if its clear, You may have bad motor bearings. Remember, thats if the motor does not spin.
2nd: Check for blown slowblo fuses on main control board iinside of control panel door. Check all the fuses for that matter. There are 4 or 5 total depending on what version you have. Most likely it is one of the fuses on the control board. Some times its hard to tell by looking at the fuse if it is bad or not. Check it with ohm meter or swap it out with correct fuse. Also there are small lights that are labeled on this board. One is for the door switch. With door closed it should be lit. Open door, no light. If that light is working correctly, and you dont have a hot motor as in step one and your fuses are good, you either have a bad contactor coil or bad motor. OR The control board itself is bad (unlikely, but possible) but make sure you check all the other possibilities first before you go replacing the expensive parts (motor or control board).
Tips: Make sure there is no water dripping into any of the electrical boxes or componants. This may be blowing fuses. I usually use 1 1/2 amp sloblow fuses on the "control boards". Check the wiring diagram in control panel to verify what size is intended to be in it. If it doesnt say, use what I use.
If your going to Rewind motors locally at a fraction of cost of new. *If you have bad motor thermistors*, buy new ones from hobart. The guys I deal with at the motor place I use, made the mistake of thinking the sensors where thermal fuses and thought they were bad. No, these are thermistors and as long as you measure some resistance in them, say over 900ohms, they should be good. Most all of the bad thermistors I've seen, measure Open (no resistance). sometimes they gradually go out and give you fits trying to figure out where the problem is, as far as the hot motor light goes.
Posted on Jul 15, 2010
Just to add. I recently replaced a motor in an am12 with the motor from an am14. I had to use 120,000 ohm resistors instead of 1000 ohm. Don't know if the resistance of the motor thermistors differ that much from motor to motor but the 1000 ohm wouldn't work on mine. The am 14 motor has a manual reset overload built on it so it is safe to use just had to bypass to get it to work.
Posted on Mar 02, 2012
What does it mean when water level is low
It means that there is a bad water switch on the water fill sensor or stop
Aug 22, 2015 | Hobart CL44E-8 - Left To Right 30-kW...
Why would a Hobart AM14 Dishwasher just fill and not wash
It seems to have failure on the lever sensor .
check the float , probe and switch assy.
Apr 11, 2015 | Hobart Dishwashers
When machine is powered down water level still fills up - Ecolab told me there was a problem with a certain sensor
need more info what kind of machine
Am 14 etc... undercounter have float switches or is it your solenoid??
Dec 21, 2010 | Hobart Dishwashers
In replacing the float that senses water level, I see that the whole assembly is free to rotate after the c-clip is reinstalled. Past experience is that sometimes this plastic float will be found...
You may have installed the stainless float retainer backwards. The hook on the retainer that holds the float faces the tank wall and fits into a flat on the probe. This prevents the rotation and will better secure the float.
Aug 11, 2010 | Hobart 42 in. AM14C-154 Free-standing...
My hobart dishwasher am 14c will not go into cycle
Check the Door switch. If the screen shows FILL but don´t do it, check all fuses on control board.
Apr 09, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Dishwasher not fillin on auto only manual
clean metallic debris off of float magnet. If float is normal, temperature/level probe or wiring may need to be replaced
Feb 02, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart am 14 electric heat does not turn on water temp just drops
Assuming that the machine fill cycle works properly and the float is intact, and the heater contactor doesnt pull in:
possible heater contactor malfunction: check for power to coil
High limit snap thermostat may be tripped or damaged ( needs to be manually reset). located in heater connection cover.
Thermistor probe and or wiring to it may be damaged
main control board may not be functioning properly. check output to heater curcuit
Feb 01, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
Oct 01, 2009 | Hobart AM14-253 Free-standing Dishwasher
BOSCH DISHWASHER Flooding
Removing the water level sensor it is not a difficult operation, it is held with one bolt at the base of the floater arm.
The problem is that you cannot be sure that the floater is not working unless you find out that the floater is filled with water or stuck.
There is an electronic test to verify if water level switch activated by the floating sensor is working. Instructions here: Bosch dishwasher helps.
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Feb 07, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Hobart AM14-253 Free-standing Dishwasher Logo
1,728 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
