Question about Char-Broil 7000 Quick Set Gas Grill
Low flame What causes low flame on high setting
  • Char-Broil Master
  • 3,087 Answers
Blocked burner , oriffce, blocked gas tap/ reg not working
Posted on May 16, 2010
Which is the lower setting on Thurcroft calor gas stove
I am not familiar with this stove but I think you could turn on the stove and look at the flame while you turn the knob to see which way is high or low.
Jan 07, 2015 | Kitchen Ranges
I get a high pitched whistle from my r94 rinnai. what causes this?
It's generally caused by either low gas pressure to the heater. Or what is called a "Cold Burner". If it is a :Cold Burner" ... Once the whistling starts, turn the heater off, wait 3 to 5 minutes and turn it back on and turn the flames to a middle setting. If there is no whistling, set your flame height/temperature where ever you like. The low gas pressure issue would need to checked by a qualified technician. At the same time, have them to check the air mixture control valve on the burner.
Hope this helps solve your problem. Please let me know.
Mar 15, 2011 | Heating & Cooling
I have a heatilator gas fireplace model gcdc60 and the flame is not high anymore. This fireplace has two settings low and high. The high setting is like having low on and the low setting is almost not...
Take a thin stiff wire and run it thru each flame port of the burner a few times each then if you can take a vacuum after setting it right on the ports-tap on the burner with a object while vacuuming it-if that does not work -is there a place that looks like a nut over each flame port? if so spray with a lubricant like WD40 to loose the nut and remove and clean flame ports that way and vacuum it then same way then
Sep 30, 2017 | Home
Low flame
Out of gas or spiders in the jet
Apr 13, 2010 | Char-Broil 7000 Quick Set Gas Grill
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Cant find the set screw to adjust the flame
some arent adjustable any more, did you look down the center of the knob shaft???? most common place for it
Mar 16, 2008 | GE 30 in. JGP990SELSS Gas Cooktop
Gas Oven Flame Constantly on High
I belive that the thermostat to the oven isnt working properly.The t-stat bulb sits inside the oven on the wall and this is what senses the temp in the oven.If its out of place or the t-stat is bad the oven will just keep heating.hope this helps let me know.HAPPY HOLIDAYS!!
Dec 03, 2007 | Kitchen Ranges
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Char-Broil 7000 Quick Set Gas Grill Logo
152 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
