Question about Niko SV3206 32 in. LCD Television
My screen shifted to the right. When using PS3
My screen shifted to the right. When using PS3 with component input the screen shifts about 6 inches to the right. When using digital cable component input the screen shifts only about 2 inches to the right. The screen seems to be shifted to the bottom as well. This happened seemingly randomly after powering on. It was working fine about an hour before problem started occurring. When I have the tv on with no input the blue screen will cover the entire screen. When using vga input I can see about 2/3's of the screen with bad res. Any ideas?
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Setup steering and pedals up on my ps3, for need for speed shift, steering work fine but the pedals wont work, one pedal changes the veiw of the screen on the game, other pedal does noth i i have the P3...
You need to go into the input settings for the game, and change the button presses for gas and brake to match the pedals that you are pushing. Hope this helps!
Feb 27, 2011 | Video Game Consoles & Games
I connected my media center PC to my new Sanyo DP50740 50" Plasma Television using the PC input on the back of the television. The instructions say that it supports 1360X768 with a 16:9 aspect ration...
No,13060 resolutions will not support by some tv correctly,will shift whole picture about to 6 inches to the right.That why,must use the PC Control panel to adjust to 1024 for the video to center.For the wide aspect 16:9 ratio,just find another aspect ratio to for expandsion to fit the entire screen.
Feb 05, 2011 | Sanyo Televison & Video
My ps3 seems to b working fine but i cant see anything. no matter which tv i plug it into it says that there is no signal
Hi aztecruler12,
For you to be able to see a picture on the screen you need to make sure that you're on the right input. Inputs on your televsion depends on the cables that you are using. PS3 supports HDMI and Component Cable (Blue/Green/Red). If you're using HDMI Cable to connect the PS3 to your TV then you need to select HDMI Input and if you're using a Component Cable it should be Component Input. To change the input you need to use the original remote of your television. Look for Input or Source button and select the input depends on your cable.
Rate me if this helps so i can help others. Thanks for using Fixya.
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
VX1935wm using analog input has image shifted ~3 in left
try to Google for service menu...then adjust from there,,
May 06, 2010 | ViewSonic VX1935wm LCD Monitor
How to turn off blue keys for an Compaq mini cq10??
if you are refering to the blue letters or alphabets which are present on the keyboard. HP designs keyboard with a billingual layout in some Notebook models.
The HP "Blue" keys are indeed the "French" input keys or other language keys.
How to use the Blue Symbols or keys on a HP Notebook:
We can activate them by pressing Ctrl+fn+right Shift.To deactivate, press Ctrl+fn+right Shift twice, i.e. Ctrl+fn+right Shift then let go off Shift while still holding Ctrl and fn, then press Shift again.
When you press Ctrl+Fn+Right Shift it will switch to the the billigual layout. That means the blue characters become prioritie.
For example, if you are in the billingual layout, when you press shift+6 you will get a '?' but not the '^' sign.
Mar 19, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
Component inputs don't work and convergence problems.
Just a coincidence..........
Are you pursuing the convergence repair---Replace the two
Stk392-560 IC's? Check for burned resistors and open
pico fuses........Let me know.....T.
Oct 08, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Niko SV3206 32 in. LCD Television Logo
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
