Question about Galaxy Radios DX 77HML Base CB Radio
Tr51 gets hot
Tr51 gets hot
  • 64 Answers
This is part of a Darlington Amplifier section of voltage regulation to the Final transistor it may be getting hot for various reasons one you may be taxing its resources by long key downs or you may have too much voltage going into the radio it should only be supplied with 13.8 Volts Maximum more than that (Volting the Radio) Will over work thhis transistor and eventually burn it out.
Posted on Sep 12, 2010
Honeywell technical support
This boiler, from memory, has an electric diverter valve.
If the system has dirty (sludge/scale laden) water then the diverter valve may not return under spring pressure, and therefore not divert all of the hot boiler water to the hot water heat exchanger, leaving some going to the rads.
If I am right then the rads will not get fully hot.
If the valve has failed completely, or electrically, then the rads will get fully hot and there will be no hot water output (hot water will be cold).
Aug 19, 2014 | Heating & Cooling
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
I just bought a repo house which has a grundfos circulation pump u p 15 installed at the water heater. House built 2005 4260 sq. Feet. House has 4 showers only one of them gets hot water. All sinks get hot...
that pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
May 20, 2010 | Home
Tr51 gets hot
Do you have a "swing kit" or a "swing diode" installed?
This could also be called an NPC ("Negative Peak Clipping") Modification. There should be a 1/2 watt 100 ohm resistor attached on the unbanded end of the diode. If it is a "Kit", It will not have a 100 ohm resistor and can cause TR51 to overheat during long transmissions.
You may want to remove the diode or kit if you have one in there and, as a better choice, change R238 (near VR13) to a 220K ohm resistor.
That will give you Killer loud audio with a stock mic. You probably won't be able to use a pre-amp (Power) mic after changing R238 to a 220k ohm.Back down the carrier power to 3 watts and watch the modulation get violent!
Apr 07, 2010 | Galaxy Radios DX 77HML Base CB Radio
Weak xmit - draws excessive current
Hi and welcome to FixYa,
On your posted description of the problem, initial check would be a possible leak of either the drive transistors(TR44 to TR46) or the finals (TR43 & TR56) for 2004 and up versions. Others to check would be TR55 & TR51.
Good luck and thank you for asking FixYa.
Nov 10, 2009 | Galaxy Radios DX-99V 40-Channels Base CB...
Car radio gets hot
There is a lot of heat generated and not a lot of ventilation so the answer to your question is yes, they all get hot. Now the question is what is too hot? Certainly we don't want it so hot as to roast marshmallows on or to melt anything or even WITHOUT TOUCHING IT too hot to touch. If it truly gets that hot there may be some trouble with the speaker or power wiring that is making it work too hard.
Feb 27, 2009 | Car Audio & Video
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Galaxy Radios DX 77HML Base CB Radio Logo
176 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
