Question about Dryers
Gas burner won't stay lit - Dryers
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryergas burner won't stay lit - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problgas burner won't stay lit - 2_bing.gif>
Dryer2_bing.gifTroubleshooting Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 13, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Jul 27, 2011 | Water Heaters
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Dryers Logo
230 people viewed this question
Top Dryers Experts
