Question about Samsung SyncMaster 713BM 17" LCD Monitor
Screen shows no image when hooked up to my pc either as primary monitor or as secondry... The screen works I just have no image.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Free Service manuals: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG&megnev2=713&kategoria=&kat2=all
Posted on May 12, 2010
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: screen shows no image
You may have failure in the backlight inverter circuits, power supply, lamps. First thing to look will be the capacitors in the power supply section, look for caps with bulging top/seal. See example of failed SAMSUNG monitors here: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net/
Post back what you see inside so we can guide you further.
Posted on Mar 23, 2010
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
My pc shows only a black screen that says Rebboot and select proper boot device or insert boot media in selected boot device and press any key. i cant get anywhere with this what can i do i am on...
first check the power supply to the booting device and also the interface cable then switch on the computer touch the booting device and see the device is working next see if the device is marked in the bios a primary master or slave or secondry mastor or slave if not shown change the power and interface able and try once more still not showing change the booting device
Sep 04, 2011 | HP Computers & Internet
No image on screen
Make sure the monitor is working first. Try hook it up to a regular PC. If it works on a regular PC then make sure your Macbook's output is setup to show the video onto an external monitor.
If you can't get the monitor to show video on a regular pc then that means the monitor is bad.
Apr 22, 2010 | LG 22" FLATRON LCD Monitor
Screen shows no image when hooked up to my PC either as primary monitor or as secondry... The screen works I just have no image.
Mar 23, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
I connected my laptop to my LCD TV using VGA cable. I changed the mode to VGA external monitor. Image/video appear perfectly fine during start up. but right after windows logged in for like 5 second the...
Easy way:
Press and hold Fn key, and then look at the F1-F10 keys.. Most likely it is F7, and has a picture like a computer screen.
So, press and hold Fn key, and then press F7 (or whatever key it is for your laptop). This will change your "presentation" settings, and thus switch back and forth from laptop screen, laptop screen + external screen (TV), just external screen (TV).
If this doesn't work as you expect, just try:
Instructions for Windows XP:
Open the Display Properties window by:
Start -> Run -> %windir%\system32\control.exe desk.cpl,@0,3
(this is the same window where you can change screen resolution).
There you will see two or more "screens", labeled: 1, 2, 3.
Click on "1", and you'll see:
[X] Use this device as the primary monitor
[X[ Extent Windows desktop onto this monitor
Click on "2", this is your TV.. Mark
[X] Extent Windows desktop onto this monitor
Then change the resolution to 800x600.
Click Apply
=> now your TV should start showing you a picture.
You can move your mouse between the laptop screen and the TV screen.
If you want just the TV, you can make "2" to be your primary monitor, by clicking on [X] Use this device as the primary monitor.
Nov 04, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Resolution Problem!!
If you have the same monitor as when you bought the PC do a default reset. should take care of it. If you have a new monitor, just keep tweaking it. you'll get there. play with the settings.
Feb 24, 2009 | Dell Computers & Internet
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
I have a Sony Vaio laptop and a remote monitor. I would like to use a split screen application where the remote monitor is the primary screen and the laptop screen is the secondary screen. "Display...
As far as I know, that is not possible. You can have both screens show the same image, but it is not designed for a true "split" screen.
The vid output is just relaying what the screen shows, it's not a true "2nd" output
Aug 21, 2008 | Sony Computers & Internet
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Samsung SyncMaster 713BM 17" LCD Monitor Logo
103 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
