Question about Nikon CoolScan V ED Film Scanner
Narrow straight line runs across all scanned images
I just installed coolscan v ed. I've scanned a number of photos and they all come out (after scanning) with a razor thin straight line running through the photo. It looks as if someone took an incredibly sharp object and ran it along a ruler over the photo. I can't tell for sure, but I think the line is close to the same spot every time. I have run through several negative strips (black and white and color) and its happened with each one. The strips are also from different rolls of film. I do not have digital ice4 enabled, but saw no reason to as these negatives are less than a week old. The photos that I had printed at the photolab don't show this line.
  • 1 more comment
  • Anonymous Jul 23, 2008
    Almost the same problem, bright horizontal line occurs but I would not call it razorsharp, just a thin bright line. Not on all scans only in slides with very light aereas or overexposed slides. (slides, so I'm talking about positives)
    The slides are old so first I thougt the old camera scratched or bended the film. But with new slides the same problem occurs in bright aereas.
  • biggmikeb Jul 28, 2008
    I get straight sharp lines through about one half of my scan of transparencies.
    Just started suddenly after excellent scans of slides.
  • Anonymous Dec 16, 2008
    I have the same problem after moving the machine from the lab to home.  Can someone suggest something besides hitting the machine?
by shutterup
I solved my problem.
It's pretty personal, but I hope it can help others.
First: I might have created the problem myself because I slightly adapted the slide-mount.
Why?: Some time ago I had some unwilling films the automatic! film-mount wouldn't swallow, so I had to use the manually operated slide mount.
I adapted a slide housing a bit, so it could take and transport film.
To be short: In the end, there was transparent, (but also reflective) material inside the Coolscan V housing, close to the slide.
I removed it.
Second, I turned the scanner 45 degrees, and gave it a calculated whack on the side. (like you did with your tele in the 6ties, but a bit more carefull )
Don't know which one did the trick, or both. I can send a sample.
Posted on Jul 29, 2008
SOURCE:
Why Nikon CoolScan V ED Film Scanner does't work with mac OSX lion?
According to the Nikon site the software for the Coolscan is not compatible for Mac OS Lion, you need to purchase silverfast to get it to work see http://www.scandig.com/filmscanner/nikon/nikon-coolscan-v-ed.html silverfast can be bought from http://www.silverfast.com/ you can download a demo from here to see if it works.
Dec 17, 2011 | Nikon CoolScan V ED Film Scanner
Trying to install Nikon Super Coolscan 5000 ED, for some reason the installation disc doesn't have the LS-5000 ED driver software...? I am running Win Vista. Any ideas?
I do not believe Nikon made drivers specifically for Vista, but you can use the solution here to make your own driver "inf" file and install some that will work anyway. Please read this and carefully follow the directions. If you are using 32 bit, use the 32 bit drivers. If 64 bit, then 64 bit drivers, when creating the new inf.
Bryan Clark
DVD Your Memories
Slide Scanning Specialists
Nov 16, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Can i share scanner across multiple computers?
Some network scanners have the ability to scan to PC's. I have the Brother MFC-465CN all-in-one ethernet network printer. This scanner lets me press scan and decide which PC to send the scanned image to.
If it is a USB scanner then I don't think this is possible.
Oct 28, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
A dark line shows up through every scan. It is indistinct and shadowy, the same look as a hair stuck in your shutter would give in a film camera. It is perfectly straight and runs all the way from side to...
There is a 99% chance that there is a human/animal hair on the reader inside under the glass.
You should take a look with a flash light, if positive then open it to clean the system out.
Oct 12, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
My new computer will not display the scan window
Did you install the scanner latest driver for your Operating system?
if not, go to the scanner manufacture's website to download it
it should be in the support tab
Good luck
Jun 17, 2009 | Nikon Coolscan IV ED Film Scanner
After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon Coolscan 9000 ED can not be recognized by computer
I am having the exact same problem...cannot get the Coolscan 9000 to show up in Device Manager. One thing I did try (to no avail) was to run the regsweeper.exe file that comes with the Nikon scan disk. It clears your registry when you reinstall. It still did not work though so I have a lovely "shoebox" sitting next to my computer that is worthless!
Dec 08, 2008 | Office Equipment & Supplies
NIKON SCAN IV ED
connect after PC start up
May 29, 2008 | Nikon Coolscan IV ED Film Scanner
Autofocus Operation Failed???
Yes, I have had the problem before and solved it by re-installing the software.  It has happened again but this time I beleive it is a VISTA related problem.
TexRail
Sep 29, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon CoolScan V ED Film Scanner Logo
381 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
