Question about Denon AVR-2105 Receiver
Just bought a denon, and wharfdale 9.1 speakers
Just bought a denon and wharfdale 9.1 speakers with no rca cables what rca cables do i need?
  • 311 Answers
This is the cable
http://en.wikipedia.org/wiki/RCA_connector
basicly a phono jack cable
very cheap in shops/ebay ect
rca stands for radio corporation of america
Posted on May 12, 2010
How do I connect Active speakers to my Denon 3805 AV receiver?
Your Genelec 1037C monitors are professional design with balanced inputs. Balanced inputs expect a low impedance signal with pin 1 earth, pin 2 hot and pin 3 cold. Because the Denon amplifier supplies a pre out for the front speakers (the first pair in the set of pre outs) at 1.2 volts and high impedance, you will need to convert the signal close to the amplifier with a stereo active DI box. Plug the pre out directly into the input of the DI with a SHORT lead and then plug two standard balanced microphone type cables ( XLR to XLR) into each of your active monitors. You cannot make a cable that is RCA to XLR by shorting pin 3 to earth to do this job properly. The inputs on your Genelecs expect a signal in the range -6dBU to +6dBU for rated output. A suitable DI box would be for example a Klark Teknik DN200. Hope that helps.
Cheers, Don.
Dec 06, 2014 | Denon AVR-3805 Receiver
Hi is it possible to connect a laptop to a denon 700aedab for music playback
HI, very possible. Just follow this instruction:
All yo need to use for the connection is to get an RCA TO STEREO JACK HEAD (use the google image to see the type of cable).. Connect to denon 700aedab, make sure that the denon 700aedab is on either aux, tunner,video,etc. Those auxillary options on your denon 700aedab.
Connect the RCA into the aux of the denon 700aedab and connect the small jack head into the laptop ( where you plug in earphones),and play and enjoy your music.
If it does not play with aux try tunner, or video, one mustplay,and if it does ot play any, that means either the port of your laptop or the denon 700aedab port is faulty.
And don't forget to connect the speaker,because diffidently you will sure hear absolutely nothing with out the speaker.
Feel free to pass your comment .
Thanks for using fixya.
Jan 10, 2011 | Denon Audio Players & Recorders
Just bought a denon, and wharfdale 9.1 speakers with no rca cables, what rca cables do i need?
What model speakers?
Didn't these things come with manuals?
Speaker connections from the Denon are typically through speaker cables (glorified lamp cord).
The Denon is not capable of driving the sub directly. The powered (?) subwoofer in your setup would presumably require an RCA cable (whatever length reaches) to feed its amplifier a bass signal from the Denon's Subwoofer Out.
Mar 23, 2010 | Denon AVR-2105 Receiver
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Speaker crackle
HDMI is a High Definition Multimedia Interface and has the capability to transmit both AUDIO and VIDEO all in one cable. Your setup right now is transmitting 2 audio frequecys (L/R stereo RCA and HDMI) into the Denon inputs. Not necessary! I would recommend eliminating the red/white audio cable from the direct tv box to the Denon.
After doing such, your receiver should be able to process audio/video signals appropriately. REMEMBER to unplug all POWER CORDS before reconnecting any speaker/audio/video cable, as it may cause a small electrical surge and fry a micro component in your system!
Feb 01, 2009 | Denon AVR588 Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Dec 27, 2008 | Denon AVR-900 Receiver
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
Denon AVR-2105 Receiver Logo
99 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
