Question about Dryers
Making a lot of noise!!! It dries just fine but is so noisy no matter what cycle I use. Is it a balance or a bearing problem? I'd like to repair it myself. It is 9 years old.
    Novelist:
  • 145 Answers
It depends on the type of sound. It could be felt pads going bad or the bearings. The felt pads are fairly easy to change as they are in the front under the drum and you just need to get the front off and replace them. The bearing assembly is a different story. You need to take the front and the top off (or sometimes the the top will tilt back on hinges) to access the drum you will have to remove your drum to get the bearing assembly off. The other problem could also be the pulleys underneath the dryer which can usually be accessed through a rear panel. I recommend running the dryer and listening really hard for where the sounds are coming from, you may have one of the problems you may have all of them.
Posted on May 12, 2010
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Noisy spinning
First make sure that the load is balanced, if you are washing and spinning a dense load like trainers etc this can cause an imbalance. If you are washing a duvet cover or a pillowcase, make sure that the loose clothes washed with it haven't migrated inside the cover or case, this happens so easily. It is always worth checking that the support feet are all touching the ground when the washing machine is empty as this can cause excessive noise
hope this helpsKind regards ki
May 11, 2015 | Washing Machines
How to I fix a load noise from Maytag Bravo washer during spin cycle?
sounds like the spin bearing has failed. it would be very costly to repair. cost of repair would exceed value of the machine.
Feb 27, 2015 | Maytag Washing Machines
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Why is my dryer is making a lot of noise during drying process?
check to see if it is a belt pulley system if it is its probably those items.
Apr 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Making a lot of noise!!! It dries just fine , but is so noisy no matter what cycle I use. Is it a balance or a bearing problem? i'd like to repair it myself. It is 9 years old.
it has the wheels that hold the drum up the shops call them tires alot of dryers take the same ones
i changed mine and it wasnt that hard and the tires were 18$ i took the drum out but you probably can get at em from behind. they get big flat spots on them
Mar 22, 2010 | Amana Dryers
Kenmore Washer: Noisy Spin Cycle
if this sound is similar to a jet engine then it may be best to get a quote from your local repair man to see if repairing the unit will be worth it. there are a lot of steps in fixing this problem and you may be able to do this yourself but it is pretty difficult.
sound like you need a new rear bearing and a spin support shaft
May 01, 2009 | Washing Machines
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Dryers Logo
67 people viewed this question
Top Dryers Experts
