Question about Yamaha HTR-5630 Receiver
Yamaha Receiver My receiver is not producing sound from the rear or center speakers or the subwoofer. We have tried all of the usual...securing wires, resetting the entire system. The problem occurred when someone who didn't know what they were doing forgot to turn the subwoofer on so when the system wasn't producing bass (duh), they tried to compensate by adjusting the controls on the display. Since they were clueless, they ended up pressing a whole bunch of buttons which messed up the system. It is supposed to be a 5 speaker system but since this happened, I get no surround sound and the subwoofer is "ON" but again, no sound production. PLEASE HELP
Did you find a solution?
Thanks
Posted on Sep 29, 2009
How to hook up subwoofer for yamaha RX-496 2channels receiver
You need to connect the subwoofer to your receiver using the speaker wire connections on the rear of the receiver. Take the speaker input from the subwoofer to the A or B speaker terminals on the rear of the AV receiver. Then take the speaker outputs from the sub and connect to the main speaker terminals. Really you need to buy a receiver with a sub out to do it properly. Sell this one and buy another.
Mar 02, 2017 | Yamaha Audio Players & Recorders
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Yamaha 2700 receiver...rear surround, subwoofer and center channel speakers all quit. Any suggestions?
Yamaha "2700"??? No letters?
That would leave you with, um, >>>stereo<<<. What switch selection would do that? Hint: sound fields or DIRECT. Then consider the characteristics of the input source. Pages i through iv in the RXV2700 manual, for example, spell out what speakers work with which sources and sound field selections.
The manual may address the problem. If not go in to the setup and make sure all speaker channels can produce the test tones.
Jul 19, 2011 | Yamaha Audio Players & Recorders
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
Jul 04, 2009 | Jensen CS10 Speaker
The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Apr 06, 2009 | Yamaha RX-V663 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Yamaha HTR-5240 no sound from main speakers
check and see if there is a a/b,a+b setting for speakers make sure its set to a
Jan 06, 2008 | Yamaha HTR-5240 Receiver
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Yamaha HTR-5630 Receiver Logo
99 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
