Question about Garden
Craftsman 1800 psi power washer won't start. Help! Thanks.
    President:
  • 1,627 Answers
Try a new unloader valve,if it is stuck the motor can.t overcome the pump and will either die or blow a breaker.
Posted on May 12, 2010
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
I have a karcher pressure washer 1800 psi i bought from walmart it was running good until i had a power surge with the plug in. what can i do can i change the fuse in the plug or do i have to open the...
you will have to take the cover off & look for melted wires or a fuse.
if there is no fuse the capacitor may have been cooked.
it should be a white cylinder.if it has been damaged it will have burn marks and may be swollen.
replace the capacitor and it should start.
Dec 19, 2010 | Karcher PSI Electric Pressure Washer
Craftsman Electric Pressure Washer 1800 psi. Start then runs for a minute then stops.
The motor overload / thermal protection is likely the cause. Check your hose and wand / nozzle for restrictions. Is this the same hose and wand that it shipped with, or is it from another machine?
Your local Sears store can get you a user manual and diagram for our pressure washer for further troubleshooting.
Jun 27, 2010 | Vacuums
New 75219 Power Washer is missing owners manual.
Any luck finding someone to give you a copy of the manual for this model? I bought one on clearance and it doesn't have the manual and I'm scared to even start it up without reading the manual as I don't want to mess anything up upon first start. If I ever do find one, I will post a copy of it for you. Good Luck! Thanks
Jim
May 27, 2010 | Craftsman 2500 PSI Briggs Stratton...
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
