Question about Craftsman 26 Hp 54" Deck Yard Tractor
Replaced starter and sylenoid - but engine won't always turn
Replaced the battery as engine acted as though battery was not giving power. Symptons with new battery unchanged. When you turn the key the starter does not turn. On occassions when it does turn over the the engine starts the starter does not disengage from the engine.
    President:
  • 1,627 Answers
Sounds to me like you need to replace the starter solenoid switch,follow the cable back from the starter post and it lead you to the solenoid.
Posted on May 12, 2010
Turn key get nothing jump starter and sylenoid just spins
i cant dope out that symptoms.
does it crank or not. be clear there.
no car starts (but my 6sp) if it dont crank.
on A/T cars cranking is a first thing. so does it.?
Solenoids do not spin, the stroke only , it a linear motion.
the Sol. moves the pinion and the main contactor switch only.
my guess is the Starter spins and the crank don\'t spin,
you hear the starter motor spin up, it sings. like bird.
that means the starter /solenoid are bad. (crude)
if the battery is good and or jumper starting off a running car.
It can just be a dirty starter pinion, clean it , repeat.
fixed many for this. i have.
battery cable lugs clean, and good. no green rust.
bad cable usually just make a loud THUNK sound. no spin.
Sep 02, 2014 | 2005 Jeep Wrangler X
Will not start. Act like it wants to crank keeps getting ticking noise
Sounds like a starter or battery fault. If the battery is low, there is enough power to operate the starter solenoid but not the starter, so you get the click of the solenoid only (Charge battery or jump start). Same thing, the starter motor is not turning, but the solenoid is clicking (replace starter). Another possibility check all earth connections ie: battery to chassis, chassis to engine. if high resistance could give same symptons.
Jan 02, 2014 | 2008 Dodge Magnum
2003 GMC 6.0L has electrical power to everything but the starter does not turn when I try to start it.
check your ground first, if your ground is good make sure the truck is in park and the brake is on. take a screw driver and touch both the positive and the ground on the starter. If it turns the engine over your starter sylenoid is bad if it still just clicks check the voltage going to the starter if it is higher than 11 volts then your starter itself is bad
Dec 11, 2013 | 2003 GMC Sierra 2500HD
I have a 2005 Polaris Trail Boss That wont turn over, When i go to turn the key, it just clicks. Even if i have it juiced pretty well by a battery charger. Kinda lost on what could be causing it. I cleaned...
attempt to start the engine in neutral using a battery charcer/starter on the starter connectors only if the engine turns over replace the battery cables if not; you have a seized engine
Sep 30, 2013 | Polaris 2006 Sportsman 90
2003 Nissan Frontier Will not turn over, All electrical works but will not turn over. Replaced Battery Terminals, Battery has 12.8 volts, Power is to the Starter when the Key is in the on position, ...
Hi
I sound like you starter motor is stuck.
tap the starter motor with a malat (rubber hammer) and try starting the car again to see if that works.
that will confirm stuck starter motor
Aug 12, 2017 | 2003 Nissan Frontier Crew Cab
My car won't turn over. i have a new battery on it ( DOUBLE CHECKED ITS FINE) It seems as tho the starter motor is'nt getting enough power to it. It just sounds as though its struggles to turn...
Sometimes the starter motor bushes can be worn out and so will work with a high level of friction which will not power the engine to turn over. Also if the brushes or the commutator in the motor is bad it will be hard to turn.
The starter solenoid also is a suspect as if this is worn out it will be delivering lower current to the motor which will not be sufficient to turn the engine .
So please remove the starter motor and overhaul.. check the starter pinion and flywheel.
Aug 12, 2011 | Renault R18 Cars & Trucks
My 2001 Dodge Durango won't start at times. I replaced battery and had alternator checked. Both checked out fine?? Help! ??
When it won't start, will the engine turn over and try to start, or does it act like a dead battery?
Jul 14, 2011 | 2001 Dodge Durango
Replaced coil, distributor module, sylenoid on fender pickup in distributor all relays and truck will not crank power going to coil no fire coming out though
are you sure the distrubitor is turning? you might have lost a timing chain. if you need it i have the wiring diagram for the truck just let me know what engine and transmission. and give me your e-mail to send it to.
Jun 22, 2011 | 1991 Ford F150
sounds like the bendix spring is bad on the starter (it's the spring that returns the gear to it not moving state)...good luck
Mar 18, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
95 jeep cherokee not starting
Check the small wire on the starter to see if you are getting 12v there with the key turned. If you are, then it is possible that the starter (&or solenoid) that checked out good last year is not good now. If no power at small wire, then check neutral safety switch.
Jan 08, 2009 | 1995 Jeep Cherokee 2 Door
Craftsman 26 Hp 54" Deck Yard Tractor Logo
218 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
