Initial DVD-2540
Problem for Initial DVD-2540
Code for Initial DVD Player
By Jimmy NY - usenet poster
I have a cheaper DVD player I purchased at Circuit City in early 2003, an
Initial DVD-2540. It's a "no-name" brand apparently, but it's done well in
the 2 years we've owned it. Plays DVD+Rs and DVD+RWs just fine, JPEG discs
as well.
Problem is, I can't find that blessed remote anywhere. I've looked all over
the creation, I just can't find it.
Most universal remote controls don't seem to work this brand. Does anyone
know of any that do?
LRH
Best Solution
posted on Aug 10, 2005
Helpful)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
  Google is your friend! Radio Shack "4 in 1 Family Favorites Remote"
lists two codes for Initial DVD players.
http://support.radioshack.com/ support_video/doc72/72876.pdf
Jim
Was this helpful?
Yes
No
Solution #2
Not Rated)
Odud
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the link. I didn't see the catalog number in the owner's
manual (PDF file) to find out which one it was. Took some searching,
but apparently this remote is catalog #15-2142 (couldn't find such a
thing in the PDF file).
Here is the link to it:
http://www.radioshack.com/prod uct.asp?catalog%5Fname=CTLG&pr oduct%5Fi...
LRH
Was this helpful?
Yes
No
Solution #3
Not Rated)
Kim1
Rank: Apprentice
Rating: 0%, 0 votes
You're welcome. Glad it worked for you.
Jim
Was this helpful?
Yes
No
Solution #4
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
As a follow-up--since I already own a Radio Shack 5-1 which I bought
about 3 months ago (Catalog #15-2115), I figured maybe (since it was
the same brand, Radio Shack) it could use the Initial DVD codes from
the owner's manual of the one you referred me to.
Right on--it surely did.
Codes 0717, 1931 were listed; code 0717 worked perfectly. All essential
functions are there; the only button I miss is the TITLE menu button
and the REMAIN button for showing time-remaining on the current
title/chapter. But the essential functions--PLAY, FAST SEARCH (FF/REW),
PAUSE, STOP, Chapter Skip (Channel Buttons), VOLUME (and mute), menu
navigation, on-screen display navigation tool (mainly for skipping
titles and setting subtitles, audio mode, etc), POWER OFF/ON--all of
these worked fine.
The only thing I don't like about that particular remote I own is that
it doesn't have dummy-defaults for things like volume-control; e.g., if
you have it in VCR mode and press volume, it doesn't activate the TV
control for that minute; you have to switch to TV to change the volume
then back to VCR. (However, when in TV mode the FF/REW, PLAY etc
functions of the VCR are activated.)
LRH
Was this helpful?
Yes
No
Solution #5
Not Rated)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
Like I said BEFORE, I'm well aware that (say) GE, JVC, Toshiba et al
will get more support than Initial, Symphonic et al.
Even so, I'm looking at my Radio Shack remote (5-1 cat#15-2115), and
I'm seeing, for instance, TV codes for brands like Admiral, AOC,
Brockwood, Celebrity. Under CD players, I'm seeing Soundesign (a cheap
brand from the 80's for crying out loud), Oritron, GPX (another cheap
80s brand), Tascam, Yorx (talk about a crappy brand). So is it such a
stretch to think that Initial might be in there?
To the other guy: thanks for the link for the OTHER Radio Shack product
which does handle Initial. I did try Google before, couldn't find
anything.
LRH
Was this helpful?
Yes
No
Solution #6
Not Rated)
Riddle
Rank: Apprentice
Rating: 0%, 0 votes
In article <yWMMd.22627$0u.9578@fed1read0­4>, n @noone.net says...
  Most of these no-name brands are made by 2 or 3 Chinese manufacturers,
with different names slapped on for different retailers. They most
likely all respond to the same codes. Even many name-brand players are
now made by the same 3rd party manufacturers, with the same codes!!
If there is a no_junk in my address, please REMOVE it before replying!
All junk mail senders will be prosecuted to the fullest extent of the
law!!
http://home.att.net/~andyross
Was this helpful?
Yes
No
Solution #7
Not Rated)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
[This followup was posted to rec.video.dvd.players and a copy was sent
to the cited author.]
In article <1107630146.293923.100 @g14g2000cwa.googlegroups.com>­,
larrytu @yahoo.com says...
  Many RadioShack remotes are rebadged OneForAll remotes. You can get
all sorts of information and code lists here:
http://www.hifi-remote.com/ofa /
 For the volume, you can first try setting Volume Lock (read the manual)
to the TV. If you don't have a DVD button, or the DVD is coded onto
another device key, then volume lock won't work for that device. You
then need to use the key remap option to map the TV volume keys onto the
DVD volume keys.
law!!
Was this helpful?
Yes
No
Solution #8
Not Rated)
Joey2
Rank: Apprentice
Rating: 0%, 0 votes
If you want good support, you dont buy off brand models....
Was this helpful?
Yes
No
Solution #9
Not Rated)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
"Larry R Harrison Jr" <n @noone.net> wrote:
Most universal remotes I've seen have a method to "search" for a code
that is not listed. You might try to find one with this method.
Basically it involves manually going through all the codes on the
remote until you find the one that works.
HTH
Jim
Was this helpful?
Yes
No
Solution #10
Not Rated)
Green1
Rank: Apprentice
Rating: 0%, 0 votes
Oh yeah, I've heard of that. Unacceptable. I want a universal that
specifically lists this brand outright. I do realize that not every
brand can be covered, and (say) Sony, JVC et al are more important than
Initial. But you'd still think SOMEONE has a remote that specifically
covers it. That's what I'm looking for.
LRH
Was this helpful?
Yes
No
Popular Solutions for Initial DVD-2540
Questions and Unsolved Problems for Initial DVD-2540
Do you recommend Initial DVD-2540?
Answer
Answer
Have a panasonic DVD Recorder DMREZ25. in the middle of recording a programme it stated scratched... (More)
Answer
Is there a way to record from vcr side to dvd side
Answer
when I taped a show, the playback is black and white and distorted. I can't remember what to do?
Answer
when I try to download from HDD to DVD disc drawer opens
Answer
there is no dvd disk in drive but it thinks there is a dvd in the drive
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Initial DVD-2540:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
