My gateway model gx70183 will not power on or off. Fan was making a lot of noise and the computer quit
  • 374 Answers
Hi there, there is already problem on fan,noise of fans could develop overload current on system and this system is protected by overload protection,it will trip off of your cpu.replace fan where ever it was located,there is fans on Power supply unit(PSU) ,also in processor,also in video card,On PSU you can replace PSU,try to find another PC which is not use,use temporary the power supply to check if ignore the tripping of your pc.Also clean the terminals of your memory card by eraser head of pencil,also with the video card.have a nice day,dont forget to fix my rate,thanks a lot.
Posted on May 14, 2010
Fan noise Gateway EC1440u
Normally, when a fan starts making a lot of noise, especially at start up, it is because they are clogged with dust and are having a hard time getting up to speed or a bearing is failing.
Jan 02, 2013 | Gateway EC1440u Notebook
My desktop computer will display anything when turned on, and the fan and hardrive both make a loud constant noise.
Maybe you need a larger power supply depending on if you might have added more hardware such as a graphics card, or an extra monitor to your system. This sometimes results in an inefficient supply of power, making your fan to your power supply work harder, thus making noise.
Nov 19, 2012 | Gateway Computers & Internet
My gateway is making a rattling sound at start up which last about 15 minutes, them seems to run quite after that.....any ideas ?
It is most likely a fan that is making the noise. It's possible that one of the fans is going bad and needs to be replaced. But sometimes fans will make noise if there is a lot of dust inside the case. You could try opening the case and using one of those compressed air cans to carefully blow the dust out. You can get them for a few dollars at any office supply store.
If you're comfortable opening up the case and replacing a fan, it's not too hard to do once you figure out which fan is making the noise. If you're not comfortable doing it yourself, take it in to a shop and get them to do it for you. It shouldn't cost much.
Right now, it sounds like maybe the fan is having trouble getting started and then when it gets quiet, it's either because the fan settles down and starts running or maybe because it just stops working after trying for a few minutes. Either way, I'd get it taken care of because you don't want it getting too hot inside the case.
Feb 24, 2011 | Gateway 838GM (RB838GM) PC Desktop
My cooling fan (not the one with the shroud) makes a lot of noise. Can I get and easily install a replacement.
yes you can replace the all fan inside, except the power supply fan . In these situation is normaly the power supply box is changed.
Jul 12, 2010 | Gateway 550GR PC Desktop
sounds like the fan has died try replacing the fan is it a cpu fan? if so it could have thermal cut out for it not working replacment in order i think hope this helps
Mar 17, 2010 | Computers & Internet
Gateway 838GM will not turn on even after installing new power supply. It was on and began making a loud noise and just quit.
Did you test the old power supply? If not, noise could have come from CPU fan. In either case, problem is most likely main board and/or CPU. Try removing all plugin components except CPU and heat sink and see if you get any signs of life.
Aug 03, 2009 | Gateway 838GM (RB838GM) PC Desktop
Multi speed fan on Gateway too loud..
You may have more than one fan.
The fan in the power supply may not be replaced, but you can replace the switch mode power supply with a newer model that has a larger fan that is very quite.
The same goes for the second fan (if you have one) that is inside the case.
Most computer suppliers have better designed and quiter fans.
May 18, 2009 | Gateway Computers & Internet
Lap top fan making a lot of noise
Check places like TigerDirect.com or Newegg.com. They have high quality laptop cooling fans & should be able to help you find one that is better than the stock fan at a better price. Hope this helps & please remember to rate my answer. Thanks.
Jan 08, 2009 | Gateway M675 Laptop
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
