Question about Samsung HCN5529W 55" Rear Projection Television
Samsung hcn5529W hmdi input dispaly issue
I have a Samsung hcn5529W that has a blue "halo" around the right hand and top edges whenever I connect a device ot the HDMI port (when I pause and connect the same devie to a component port there is no halo). This is particularily noticable when the screen is dark.
Additionally, on all input, there is a blue halo whenever there is a whiteedge meeting a black edge. Has anyone ever seen this or know how to fix it?
  • jrfarrow Mar 29, 2008
    "then try using RY able instead of HDMI input to test if its a cable problem"
    What did you mean by "RY able"? I think there is a typo in there somewhere.
    Also, to be clear, it is a DVI input, not an HDMI - I mis-typed in my original question.
    Based on your recommendation, I will call Samsung to inquire, but I am confused why a screen issue would affect the image only on the DVI input.
    This is a 55 inch screen.. I am currently looking at Samsung parts, and they have 3 differnet screens - the sun screen, the lenticular screen, and the frensel screen. Which do you belive it to be?
  • 1,894 Answers
Then try using RY able instead of HDMI input to test if its a cable problem
Posted on Mar 29, 2008
  • dewan nafees ahmed Mar 29, 2008
    else this must be a screen issue.
    please note down the part number from your service bulletin published by Samsung and get it replaced.
    IF it is a 50" TV then here are the info you need
    50" Replacement Screen Info:
    Part Name: ASSY MISC-SCREEN SVC; 50L3, DNP
    Part Number: BP91-01811A
    The aforementioned part number is for the screen *assembly* (ie. both
    halves) that comes with two screens taped together around the edge. The
    replacement screen assembly must have a sticker on the upper left hand side
    (when facing the viewing side) with a part number. The tech tell
    this part number was for the *outside* half of the screen (viewing
    Outside Screen Part Number: BP67-00137A
    The *old* screen also had a part number listed in the same place on the viewing side.
    "OLD" Outside Screen Part Number: BP67-00153A
    also adjust the DMD board to align the picture for overscan, and then go into the service menu and further tweak the Vertical and
    Horizontal settings using the overscan test pattern in DVE.
    NOTE: please dont attepmt to do this until you have prior knowledge of what you are doing. trying all these with out hands on experience will lead you to messing up with some big problem. even after this you want to try this then you will do at your own risk. we may not be held responsible.
    thank you
    good luck
    no no.. please ignore that first post.. after doing further research on you post i was able to figure that this is a screen problem for sure..
    sorry for that error
    thank you
Plasma screen is blue it has been taken off wall think something may have been touched/flicked
Blue screen means no input. First make sure the HMDI cable and the device you get your golf results from is properly sending the signal. After that, you can then make sure that the TV screen itself works right by using the remote to change volume and ensure that it the screen shows the volume up graphic display. Once you know that is in working order, make sure you are on the right input channel by looking at where you input is plugged in to and setting the TV to that input via the remote. You can repeatedly hit the input button to cycle through the inputs if you want to be sure. (there are 8 of them) The last thing you can try is assume that the input you are using is bad and switch to another. (Go from HMDI 1 to HMDI 3)
Jun 14, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Have a rear projection tv 55pp9352. Has green halos around objects on the screen. Checked convergence and all red and blue line up except that on the outside edges the convergence crosses are somewhat...
yes, you need remplace the liquid in the picture tube green and blue, and need remplace 2 parties stk-392-120 and resistences 6.8 ohms at 1/2 watts
Jan 05, 2010 | Televison & Video
LG 32LF11 HDTV is haveing blurring issues, meaning that in some instances ( like digital art ) colors blend together or i should say bleed together, like if i take a red background and put a black line...
I have a similar issue with Samsung LN46N610. Red (and green to a lesser extent) text or graphics on light background creates something like a shadow or blurred edge. My PC is connected to HDTV via HDMI cable. I don't have this issue when I use Toshiba 46XV645U (Toshiba a different audio problem though) HDTV
Jan 03, 2010 | Televison & Video
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
I have a blue icon in top left hand side what does this mean
if is a little blue E, then it means your connected to the EDGE network, which is a 3G technology that only runs at about 2.5 to 2.75G
Dec 04, 2009 | Samsung Jet S8000 Cell Phone
Broken samsung hcn5529w
its not the cap. its the flyback xformer
Aug 29, 2009 | Samsung HCN5529W 55" Rear Projection...
I have a Samsung HCN5529W projection tv. The
yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Feb 20, 2009 | Samsung HCN5529W 55" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung HCN5529W 55" Rear Projection Television Logo
127 people viewed this question
Jerry Greenberg
Jerry Greenberg
