Question about Dometic Rooftop RV Air Conditioner
Wiring Diagram Coleman Electra Heat Mach EL
Need a wiring diagram for this unit.
    New Friend:
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
Posted on Jul 13, 2010
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Internet soul man!
Posted on Aug 28, 2008
SOURCE:
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
Need wiring diagram for Emerson MW8992RD microwave.
Try google make model images wire diagram. you may find a diagram or perhaps images of.
Apr 09, 2015 | Emerson Heating & Cooling
Bought a used coleman 15,000 btu with heat pump.The wiring harness came seperately and I don,t see a place on the unit to wire it in. The wire diagram shows 24volt control but there is no transformer in...
You'll need the ceiling assembly and control box to operate it properly, or at the very least a ceiling assembly with mechanical controls. The ceiling assembly is where you will run your 110 volt, and depending on what set-up you choose, the wiring etc, relays and transformers will be determined by that. I assume you didn't get the ceiling assembly with it? Here's a link to wiring diagrams etc and service manuals to help you understand what and where to go with it. Model number should be on it, just go to proper info pertaining to your model.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Jun 12, 2011 | Coleman Mach III Air Conditioner
How can I get a diagram of the wiring for Coleman A/C & Heat Unit...model DRHS042100
If you go to the coleman website for residential Air conditioners you should be able to find a diagram. If you need help with a certain part to wire I can assit you with that.
May 02, 2011 | Coleman Heating & Cooling
I am changing the 3 capasitors on a coleman mach and i need a wiring diagram
You may want to check the PPL parts superstore website as they have a good
parts diagram of the air conditioner. Although I only see one capacitor and it has
two leads.
Mar 01, 2011 | Coleman Mach 15 Air Conditioner
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
1,201 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
