Question about Kenmore 62722 Electric Dryer
My Dryer has power, spins the drum, but only air
My Dryer has power spins the drum but only air drys (no heat). We can actually open the door and it will still spin meaning a faulty door switch. Would replacing the door switch fix the heating problem as well or is there something else I would need to do?
    Novelist:
  • 145 Answers
Well I know that older dryers came with a wiring schematic for where all the wires go, but yours may not. There is a lot of experimenting with dryers when it comes to diagnosing. I would say that it is very possible a door switch could cause that depending the position its stuck in. If no power is going through that switch then the heating elements may work off of whether that switch switch is operating or not. If your heating elements worked before this then I would have no doubt that they are working now. If the switch being replaced doesn't work I would then go and check for full voltage at your main terminals (120V per power wire and 240V across both of the wires)
Posted on May 12, 2010
Dryer powers on but drum does not spin and no heat. Drum is free by hand and door switch is functional - light goes on when door opens.
If you can hear the motor running when you turn the dryer on but the drum does not turn, it may be that the belt has broken or the idler has come loose. You don't mention the make and model of dryer but most are driven by a long belt that goes from the motor at the bottom of the dryer over the drum. It is held tight by an idler pulley. Google "drum will not turn" along with your make and model so find out how to gain access to the underside of the dryer to make sure the belt is intact.
Aug 12, 2015 | Dryers
Aeq6000 won't turn off
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Oct 20, 2012 | Frigidaire AEQ6000ES Electric Dryer
Dryer powers up but won't start - smell of electrical burning. Is it the motor bushes? zanussi TC7103W
Electric dryers usually have a motor with a switch that prevents the heating element from being powered until the motor is spinning. In series with this are limit switches to prevent overheating if there is too much lint or too little air flow around the heating element. Also, the motors are induction or brushless. So the smell is coming from the heating element burning off some lint nearby as it reaches the high limit temperature and shuts off. This can be due to two conditions if we can assume the motor is running (has a switch that is closing to power the heating element). The most likely condition is that the drive belt is off the pulley or broken and the drum is not turning. You will be able to tell this easily by sounds or by opening the door to see the drum slowing down. If that's not it, examine the blower which forces air through the drum. There are a lot of variations, so look for air intake and drum exhaust ports that can be clogged with a sock, lint, etc.
Dec 12, 2009 | Zanussi TC7114W Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Maytag sde3606ayw make loud screeching noise
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Dec 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Fridgidaire dryer
In dryers, the small clothes can get caught in one of the drum seals and make a scrapping noise, ( remove power, grab a flash light and have a peek inside through the door opening ) or the cloth can actually pass through one of the heating duct holes at the back of the drum and touch something electrical like the heating element, thermostats and so the noise comming.
Nov 03, 2008 | Frigidaire GLER642A Electric Dryer
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 62722 Electric Dryer Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
