Question about Mitsubishi WS-65611 65" Rear Projection Television
Remote won't work tv, and stuck in volume down
The remote will not power on the tv or make any of the menus appear. it will however operate all the devices connected to the tv. Also after about 1 minute the tv enters a system reset and shuts itself off. Also regardless of batteries in the remote or whether the audio system is on or off the tv is stuck in volume down. Its really messed up.
    Sergeant:
    Champion:
  • 301 Answers
You sound like you might be having front button problems. if you take the front speaker grill off then unplug connector ZF and it restores normal operation than the front panel buttons are bad. basically the tv will respond first to the buttons and nothing else until the button is depressed.
Posted on Mar 29, 2008
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
Jan 16, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
'left' or 'volume down' function appears to be
The volume down button on front of TV is stuck down or the switch is bad.
May 02, 2010 | Televison & Video
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
Aug 07, 2008 | Samsung TXG2548 TV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
Mitsubishi WS-65611 65" Rear Projection Television Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
