Question about Whirlpool SB160PEE Gas Single Oven
Oven problem Oven start to worm and stop
  • Whirlpool Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Posted on Aug 29, 2010
Model DED0530 wall oven. Tries to start but then why does it indicate 'cooling error lower one'?
[PDF]Viking Use & Care Manual
Viking Rangecontact our consumer support center at 1-888-VIKING1. We appreciate your choosing a... Error Handling .... *Note: Professional Series Premiere model control panel and features are shown. Oven ... upper or lower oven, and then set the desired temperature. .... cooled, remove any ash from oven surfaces with a damp.
Nov 06, 2015 | Ovens
Viking electric oven fan starts and stops, blinking clean light
Try the door latch...seems it might be the cause of your grief.
Nov 30, 2013 | Viking Ovens
In my oven the microwave is not getting worm .all other elements are looks ok
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Feb 04, 2011 | Ovens
I have a whirlpool gold self-cleaning oven accubake system super capacity 465. The oven will not get worm. The burners work just fine. The oven runs thought it pre heat time but never gets worm.
While I can't solve your problem, I can say, you are not alone. I own this oven and have been having major issues with it, I have had service men out to my house 3 times and still it isn't fixed. We were told that this particular oven is an experimental only has 4 working parts. The pilot/ignitor for the burners AND unit are the same, so if burners work it has nothing to do with your pilot light or ignitor. More than likely it is the thermostat OR the motherboard. Thankfully we have home owners insurance and have only had to pay $60 to get them to come and fix it. If you are not so lucky you may just want to call Whirlpool, give them a piece of your mind and then go buy a different brand oven.
Jan 15, 2011 | Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
Beeping noise from oven - won't stop
Try going to the fuse panel and shutting the breaker off to the oven for about 15 minutes. Hopefully the EOC ( electronic oven control ) will reset it self and you will be good to go.
Apr 03, 2010 | Ovens
The display on the oven has completely stopped
try to repair it, but ask for the price first, if it's too high, just buy a new one
Jul 21, 2009 | Ovens
Error f1 and beeping sound when the oven is on. Heating non stop.
Your digital panel may still be under warranty. It may be worth your while to have a tech look at it. Something else is going on here.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Whirlpool SB160PEE Gas Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
