Question about DeLonghi D882UX Cool Touch Roto Deep Fryer
Replacing oil drain tube on Delonghi rotofryer the oil drain tube has developed a leak and requires replacement. I have the part. I cannot figure out how to access where the tube attaches to the oil reservoir. Need help.
SOURCE: Delonghi Rotofryer filters
Just had the same problem myself and eventually found the answer.
The white filter must rest on the metal part and the coloured area must face upwards (or towards the black filter)
You can download the user manuals at the following
http://www.delonghi.co.uk/pdf_files/F18_series.pdf
Hope that helps
Posted on Jun 28, 2008
  • 134 Answers
SOURCE: REPLACEMENT FILTERS
Hi
here you go
http://www.delonghi.com.au/company/contact_us.asp
Please leave feedback
Posted on Feb 13, 2009
SOURCE: De'Longhi Rotofryer FRP Easy Clean Fryer, 1kg instructions
Unfortunately the model you have does not have the drain tube. The FI8 is the model you are thinking about. The FRP has an arrow at the side of the rim to show where to tilt the fryer AFTER THE OIL HAS COOLED, FOR TWO HOURS AT LEAST!! Hope this helps you.
Posted on May 26, 2009
my rotofryer was working fine but now will not heat up.
Posted on Jul 09, 2009
  • 102366 Answers
SOURCE: My mother has a DeLonghi RotoFryer Easy Clean
D895UX: http://delonghiusa.com/downloadpdf.php?nid=73
D28313UXBK: http://delonghiusa.com/downloadpdf.php?nid=152
Posted on May 31, 2011
I'v got an Oil-filled heater model: Dragon sometime I see some oil on the floor: 1- is it danger to use? 2- How can I fix it? I dont have warranty Cheers
As far as it being a danger is concerned ... only for a slip and fall situation. Yes, it can be repaired, but it would mean draining all the oil after finding the leak, so that it can be repaired. And of course, it would have to be refilled after the repair is made. Personally, I'm not a big fan of repairing leaks in oil heaters. As, my experience has been, if it leaks once it will leak again from another source. Replacing it, is the optimal thing to do. Plus, you will then have a warranty on the heater.
iI you decide to repair it rather than replace it, you can use a product called JB Weld. Which you can find at most any auto parts store. Follow the manufacturer's instruction on the tube when using it. Be sure to drain all the oil in a very clean container, that can be lidded, while the repair is made. You Do Not want he oil to become contaminated.
Hope this helped you to solve the problem, one way or the other.
Jun 02, 2011 | DeLonghi TRD0715T Oil Filled Radiator...
My rotofryer has overheated and cut out. is there
no this is fitted with a thermal safety fuse
Feb 13, 2010 | Microwave Ovens
1999 Chrysler Sebring Coupe 2.5 oil in spark plug tubes. Replacing valve cover gaskets and spark plug tube seals at top of tubes. Concerned about bottom of tube. Is that an area that might also be...
It is possible the tubes are leaking at the bottom but highly unlikely. There is next to 0 oil pressure in that area so the tubes would actually drain if leaking. I would start with the tube seals and gaskets as you have already planned and check it again later down the road like at the next oil change interval. You're on the right track for the repair, just be patient with the intake plenum and you'll do fine.
Jul 27, 2009 | Chrysler Sebring Cars & Trucks
DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Jul 14, 2009 | DeLonghi Dehumidifiers
Mar 20, 2009 | DeLonghi Kitchen Appliances - Others
REPLACEMENT FILTERS
Hi
here you go
Feb 12, 2009 | Kitchen Appliances - Others
Hope that helps
Apr 05, 2008 | Kitchen Appliances - Others
Delonghi 5 fin 700/800/1500w, oil filled heater.
It sounds like you have a lemon. The heat exchanger tube has developed a hole somewhere. These things are designed for the small element inside to heat up the oil, and that is supposed to radiate the heat. It would be dangerous to use without any kind of oil. The element would burn out hopefully before it started a fire, but not necessarily. I don't know what kind of oil they use, but its a thin viscosity, like some turbine oil. You can patch the hole and try some pump oil or something, but I personally don't think its a good idea. I wouldn't do it.
Mar 01, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
DeLonghi oil filled heater typ.061563
Hello I have a Delonghi KR031225 found that after turning it on and it heated up it began leaking on the bottom corner on the same panel that holds the controls? What could be wrong? Is it beyond repair?
Thanks
Mel
Jan 29, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
DeLonghi D882UX Cool Touch Roto Deep Fryer Logo
130 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Paul Bade
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
