Casio PC Board Assembly
There is an older lady in our church who has a Casio CTK-555L keyboard. I purchased an ac adapter for her to use instead of buying batteries all the time. I found out that another lady had purchased an adapter but was probably the wrong one and when she was trying to get it to fit, it appears that she broke the connection on the keyboard. I have located the part that I think I need (Casio Part # 69270460) but before I order it I wanted to know if it just basically plugs in or is replacement more complex (ie. soldering different wires etc.)?
  • datfire Mar 29, 2008
    Thanks Ginko for your input. I was told by PAC parts that the connection that the adapter plugs into is a part of the pc board assembly and though the lady with whom I spoke said she was not a service technician, it appeared that the board had plug in connectors and would be simple to replace. That part number is listed as PCB ASSY, SUB (MA2M) on their website.
  • 19,396 Answers
I do not know what part is # 69270460, it does not come in my part list. if it is the power supply socket on your keyboard, then it should be quite an easy task, providing that you have experience in soldering electronics. Todo the job you will probably need Casio schematics and service manual for 555L.
This website ask to do a donation to charity and will send the schematics. Give them (or ask the ladies) proof of recent donation to charity.
Alternatively this website sells schematics and service manual for a price between $10 and $20.
Regards
Posted on Mar 29, 2008
My CTK 720 isn't powering on from the adapter anymore but battery power is working. I bought a new adapter but it still isn't powering on. Can this be repaired?
This could be a loose plug inside the unit or it could be a circuit that is bad. If the plug failed it is from physical damage from something like tripping over it or heavy use. That can be repaired by replacing the plug. If it is something like a component in the unit on a board then it becomes a little more involved.
Mar 26, 2016 | Casio CTK-720 Electronic Keyboard with...
What do I need to do with my Casio CTK 700 which will make it run on batteries?
If you turn it over, you will see the battery compartment. It runs on 6 AA batteries. Here's a link to the manual. Instructions are on page 13.
http://support.casio.com/pdf/008/ctk_496_700_e.pdf
Feb 25, 2015 | Casio Music
Computer does not have Ctk-720 driver
PC drivers available at Casio
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a MAC google casio driver for Macs by 3rd party.
Jan 22, 2014 | Casio CTK-720 Electronic Keyboard with...
I have a Casio CTK 551 Keyboard, when the AC adaptor is connected and power is turned on, the Keyboard lights up for a few seconds then turns off. I noticed no red light lights up when the AC adaptor is...
The adapter has a problem... likely a poor connection of input power that briefly contacts building up some voltage that is then stored in the capacitors in the adapter which then discharge quicklly when you turn on the Casio. The adapters with FIXED blades OFTEN have problems contacting the connections in wall receptacles and extension cords. You may need to bend the blades slightly or use a better receptacle like connector. IF your adapter has a three wire cord from it to the wall receptacle, those SOMETIMES don't seat well...
Apr 10, 2011 | Casio Ad5mr Power Adapter Lk Ctk Wk New...
My Casio keyboard won't play with the ac adapter but plays when I install batteries. Why doesn't the ac adapter work?
Test the continuity of your Adapter (input and output), if it fails your test replace it with the same output voltage requirement's and watch the polarity as well (negative ground mostly or positive ground).
Aug 12, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Casio CTK 800 spare key
I can think of two places. eBay search for
Casio LIGHTED KEY KEYBOARD or call casio and explain to them what happened and see if they can help :) Steven.
Apr 14, 2010 | Casio Lighted Keyboard LK90STADMC
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
Need owner's manual for Casio CTK-500 keyboard
I can help you with the manual. Here is a link:
CTK-500 Manual
I'll try to find an adapter. Are you in the US?
Use the Comment button to reply.
Thanks for using Fixya.
Jun 18, 2009 | Casio Portable Keyboard Touch Sensitive...
Computers & Internet Logo
415 people viewed this question
David Payne
David Payne
