Question about Refrigerators
My kenmore sidexside quit cooling and freezing. Repairman said it was the relay and compressor without using any tools. Relay was burnt. How can he know the compressor is out too? model 106-54502300
    President:
  • 1,218 Answers
Good day,
He can't, although it's a good guess. However, The compressor can be tested and run with a special test cord most all techs have.
It allows the compressor to be run independent of the rest of the machine and is the definitive test. I would not go forward unless that test is performed. Compressors are too expensive.
Posted on May 12, 2010
Freezer quit freezing ice cream Thur night, but everything else was fine, not everything is starting a slow thaw
either the ptc overload relay on the compressor is bad and the compressors not operating to cool the unit or the evaporator coil behind the freezers inside wall is iced up and cant let cold air out due to this blockagethen its a defrost heater/thermostat on the evaporator coil issue
Jul 02, 2011 | Kenmore Side by Side Refrigerator
My under counter ice maker quit working. I went to twice ice and it quit making ice completely. Question on the pump. Should it work all the time or is there a temp relay that tells it when to come on? The...
Most likely you have a refrigerant leak and there is not enough to freeze the ice. The compressor will run almost constantly trying to cool the unit. Sears repair can give you a better answer since this is a Kenmore unit. They have a toll free number you can call and maybe they can give you a cost estimate so you can determine if you want to fix or replace the unit.
Dec 06, 2017 | Kenmore 51lb. Clear Ice Maker
Fridge not cooling or freezing
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 12, 2010 | Kenmore 52673 Side by Side Refrigerator
Fridge not cold
The overload/relay is probably burnt out . This is the piece which plugs onto the compressor , with 2 or 3 wires going to it . It is easily replaceable , and not near as expensive as a new refrig .
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a Frigidaire sidexside, purchased in May 2005. The compressor does not come on, and will produce a 'buzzing' sound for approximately 17 seconds. Then the 'buzzing' sound will cease and all is quite....
sorry to tell you that your compressor is bad, what you are hearing is the compressor trying to start, but unable due to shorted windings. not a cheap fix. sorry.
Mar 30, 2008 | Refrigerators
Side by side quit cooling - freezer & fridge
look on the compressor if there is a white relay box on it take it loose and shake it if it rattles and black stuff falls out go to the appliance parts store and tell them you want a three in one relay follow the instructions its easy and you will be fixed
Feb 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing
How old is the unit? Does it seem to have air circulating in freezer? Is the temp in the refrigerator side cold enough? One common thing is for the defrost heater to stop working which causes the freezer to ice up and stop circulating air. If you can put all items in a cooler and unplug the unit for several hours leaving the freezer door open. Plug it back in and see if it starts blowing frost again. That would indicate a bad defrost system. It can be several things but most common are the heating elements. If the defrost timer stops working you get the same results. If this does not produce positive results then it could be a weak compressor or gas leak. Best have a repairman check it or get a new one if it is the compressor.
Jan 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Dec 17, 2007 | Refrigerators
Kenmore not freezing nor cooling. humming noise
DONT SAY THAT COMPRESSORS BAD YET !!!! TECHCUMSE AND COPELAND ALL HAVE THE SAME COMPONENTS FOR STARTING THE COMPRESSOR. ALL COMPRESSORS HAVE EITHER A "PIN-TYPE PLUG-IN START RELAY, OR CAPACITOR START ASSIST RELAY" TO GET THE COMPESSOR TURNING.( FROST-FREE REFRIGERATORS ALMOST ALWAYS HAVE A START-CAPACITOR, RELAY, AND T-STAT COMBO ON ALL MAKES. THE IN LINE BI-METAL TYPE T-STAT THAT PREVENTS THE COMPRESSOR FRON OVER HEATING... THEY CAN GO WEAK. THIS IS THE "CLICKING SOUND YOU ARE HEARING !!! CALL A REPUTABLE DEALER THAT IS "FACTORY CERTIFIED" FOR YOUR MAKE AND MODEL AND GET A "FLAT-RATE" DIAGNOSTIC CHECK PERFORMED. NEVER LET A REPAIRMAN TAKE DEFECTIVE PARTS OUT OF YOUR HOUSE FOR ANY REASON. BY LAW THEY HAVE TO LET YOU KEEP THEM UNLESS THEY ARE REPLACING THEM COVERED UNDER WARRANTY FOR EXCHANGE. UNFORTUNATELY HUNDREDS OF CONSUMERS ARE "BILKED" BY THE " DOI-IT-ALL REPAIR-MAN. MOST MANUFACTURES ONLY HAVE 1 YEAR ON COMPRESSORS FOR REFRIGERATORS 5-10 YEARS ON A/C COMP. DONT BE AFFRAID TO WATCH AND ASK QUESTIONS TO REPAIRMEN YOU LET "INTO YOUR HOME".
Apr 27, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
