Question about Toshiba Satellite P35-S605 Notebook
Continual reboot with second memory module
I just bought a 1 gig memory module to add to the 512 mB module that was already installed. When both are in the computer, it continually reboots and never powers up.
I I install either module by itself, the computer works fine.
Any ideas? thanks, dave
  • 667 Answers
Your memory isn't an exexact match. The 512MB you have in is probablyis Kingston, part # KT3311/512, PC2100/2700, 512MB DDR. You should get Kingston part # KT3311/1G, PC2100/PC2700, 1 GB DDR. You can use another manufacturer but everything must match exactly execpt the size of course. The speed, DDR, everything. Make sure you have the new chip seated correctly and in all the way first. Of course if it doesn't match the specs of your other chip it won't matter. Best thing to do if buying locally is take the first chip with you. If not buying locally, have it with you when you order to make sure it matches.
Posted on Mar 29, 2008
SOURCE:
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
Can I add 1 gig of ram to an old Vaio PCV-RX280DS with Ubuntu Linux installed?
no, i'm sorry the maximum amount of ram the motherboard will recognize is 512 mb, it's not an OS limit it's a MOBO limit
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Mar 15, 2012 | Sony VAIO PCV-RX280DS PC Desktop
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
Just need to know how to change the ram in my Sony Vaio PCG-v505ap
visit vaio manual in
ftp://ftp.vaio-link.com/pub/Manuals/Notebooks/
You can do this in two ways: opening your notebook and taking a look on the memory modules already installed (we will explain more about this later) or running a program like Everest (available on our download section). We ran Everest (going to Motherboard, Chipset, Memory Slots) on our notebook and found that it was using two 256 MB DDR-SDRAM PC2700 (“DDR333”) modules, for a total of 512 MB.
imageview.php?image=1680
click to enlarge
Figure 1: Checking your current memory configuration with Everest.
If your notebook has an empty memory slot, just go to the computer store and buy a new SO-DIMM module with the same technology (SDRAM or DDR-SDRAM) and speed of any capacity you want – of course you need to know the capacity limit of your notebook. You cannot install a 1 GB module in a notebook that only accepts modules up to 512 MB, for example. Our notebook – a Sony Vaio PCG-V505ECP – accepts modules up to 1 GB, for a total of 2 GB RAM, since it has two memory slots.
For example, if your notebook has one 256 MB module and an empty memory slot, if you buy and install another 256 MB module, it will have 512 MB RAM. If you buy and install a 512 MB module, your notebook will have 768 MB.
If your notebook already has two memory modules, you will need to remove one of the installed modules in order to install the new one. If the two modules have the same capacity, it doesn’t matter which one you will take away, but if they have different capacities, remove the one with smaller capacity. The new RAM capacity of your notebook will be of the capacity of the remaining module plus the capacity of the new module.
In our case, our notebook has two 256 MB modules. So we will remove one of these modules and install a new one on its place. We bought a 1 GB-module, so after installing it our notebook will have 1,280 MB RAM installed (memory math is tricky, since 1 GB equals to 1,024 MB not 1,000; so 1,024 MB + 256 MB = 1,280 MB).
else visit
http://www.hardwaresecrets.com/article/189/1
Jul 02, 2009 | Sony VAIO PCG-V505DXP Notebook
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Open Questions:
Canon Printer tEcH SupPoRt pHoNe nUmBeR:~{-1{85526O0O64^-} Musary Canon Printer tech Support Number +1{{85522l4867}Wireless Repair service center to resolve all Canon Printer customer service phone Number products. Canon Printer ROUTER is an American multinational company which was founded by Michael Canon Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Canon Printer ROUTER support number, and selling of computer-related services and products. Canon Printer ROUTER Tech Support Phone Number Recently, Canon Printer ROUTER has been named the number Canon Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Canon Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Canon Printer ROUTER Service Tag or a Canon Printer ROUTER Get Canon Printer ROUTER Technical Support Phone Number and Customer Services. Canon Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 17, 2019 | Canon Computers & Internet
AVG CUstOmEr care pHone ~+18OO8-O31O69 NuMbEr u.s.a-24/7 Usa AVG USA phone number is ranked #2 out of 2 because 7,728 AVG USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVG USA Customer care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, AVG USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVG USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVG USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVG USA Calling AVG USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVG USA Customer care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVG USA's Customer care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVG USA's phone numbers against each other. Contacting AVG USA in General While I8OO8O31O69 is AVG USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVG USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVG USA.
Oct 17, 2019 | AVG Computers & Internet
See all Toshiba Satellite P35-S605 Notebook Questions
Toshiba Satellite P35-S605 Notebook Logo
169 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
