Question about Mackie 1202vlz3 12 Channel Mixer
Control room out issues
Is there a way to set up the control room out so that I can raise and lower out to speakers without lowering in put to my computer?
  • Mackie Master
  • 5,603 Answers
There is a volume control where you select the source of the control room signals. There is NOT a slider type fader. The same pot that controls the phones varies the control room speakers.
You could also use one of the AUX to drive your control room speakers, however they are usually used to drive the stage monitors.
Posted on May 12, 2010
Wish to bridge onto mixer output to send to separate amp for use in another part of bldg. without interfearing with regular speakers. Peavey XR684
simple !! most peavey mixers have a monitor output !! you can use that to feed new amp , and theres your volume too !!! or if your already using the monitor output , you can buy a split cable (1 in 2 outs) for main send !! this cable would have to be kept short or it will induce HUMMM !! and in real extreme cases if your using a low Z send (cant think as to why ) a device known as a (direct box) normally used by instrument sends can be used in reverse to "tap" into a low Z send and output with a unbalanced send for an amp to your other room , but hey why not just add a speaker with a volume control to it for this smaller room ? and forgo the new amp
Oct 05, 2016 | Peavey Music
The lower keys wont work without harmonization
Sounds like you have the accompaniment function selected. Find the button on the front panel and deselect it and you will get full control back
Feb 01, 2014 | Casio Keyboard Power Adapter
I need to know how to raise and lower the pitch
In principle, the primary oscillator needs to be adjusted- some keyboards have a pitch or bend control that if not set correctly, it will affect the tone of the entire piano.
Apr 05, 2012 | Music
How do I slip a shiv between neck and body to raise action
Might want to rethink that....to raise the action is to have the strings higher off the fretboard....if you shim the neck in relation to the body, you'll actually lower the action. To raise the action you need to raise the height of your bridge/saddles. If you want to lower the action and the bridge/saddles are as low as they can go you could remove the neck and insert some card - might have to do some trial and error but to my mind...to shim enough to significantly lower the action, would take a thick shim and you might not get a good tight fit between neck and body. You might actually need a truss rod adjustment - not an amateur adjustment.
Mar 25, 2012 | Music
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
How to lower the action on a les paul safely
The bridge should be on two posts, both of them with knurling on the edge. These screw into the body of the guitar, allowing you to raise or lower the action of the strings. Turn them clockwise to lower the action, making sure to turn them the same amount, so as to keep the strings even. You WILL have to re-adjust intonation after this.
Hope that helps!
Feb 11, 2011 | Gibson Les Paul Studio Electric Guitar
How to lower the action on a b.c.rich warlock bronze series
To fix the action on your B.C.Rich Warlock, you need an Allen Wrench, or Hex key. There is a truss rod cover on your B.C.Rich's headstock. Just open it using a screwdriver and you will find the truss rod. Then adjust the action using the hex key.
check out more here -
http://www.squidoo.com/b-c-rich-warlock-set-up-and-fixing
Nov 20, 2010 | B.C. Rich Dark Arts Warlock Electric...
You seem to be the expert - i just got my pmp 4000,,,,i'm a little confused,,i understand the concept of side A for mains,,(mono) and plugged monitors into side B -got sound out of both mains and...
The MON faders ONLY control the output to the MON L and MON R jacks, NOT the split use of MAIN/MON outputs. You MIGHT try varying the MONO fader and see if it varies the MON part of the split output.
Best to use the unit as MAIN L and R to main speakers and use a stereo amp or POWERED monitors driven from the MON L and R jacks. With this, the MON faders will control your monitors as you would like them to.
ALSO make sure ALL equipment connected together is powered from teh same recepacle power system. Powering interconnected equipment from receptacles at opposite ends of the room is asking for damage due to ground bounce and faults.
PLEASE read my tip on here about a HAZARD of speaker polarity if you use Speakon to 1/4 inch cables.
Oct 29, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
set up the control room out to your speakers set up the main out to go to you comp
that way you have control over the volume of both these seperately
Mar 17, 2010 | Mackie 1202vlz3 12 Channel Mixer
Floyd rose is causing a fret buzz
Raise the saddles on the FR to help take away the fret buzz. Check the neck for curve. If the neck has a VERY slight bow on the fretboard side the strings will be able to vibrate better without buzz. Also might want to step up to a heavier gauge string set if you play in lower tunings.
Dec 05, 2009 | Jackson Dk2m Dinky Electric Guitar
Mackie 1202vlz3 12 Channel Mixer Logo
65 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
